Question about NetGear Computers & Internet
Netgear cli cli documentation
Posted by Louis Evart on
Tomislav Marinovic
  • 205 Answers
NETGEAR FVS338 Comand Line Interface (CLI)
FVS338: />
bin/ config/ stats/
FVS338: /bin>
ls - lists available commands
cd - changes current working directory
help - Used to list directory or help for a specific command
version - Get the Product/ModSets Version history of the image. Usage : version -all
logout - Closes the Current Session
shell - Run a unix shell
linux-version - Prints the Linux-Mod-Set Version
ping - ping <ipaddress/host> [-c count] [-f] [-s packetsize]
ICMP ECHO REQUEST Check statistics
FVS338: /config>
sys/ sntpc/ ip/ ether/ polgrp/
userdb/ ldsv/ snet/ ad/ iapd/
firewall/ relay/ upn/ algs/ tcpreasm/
diag/ trace/ ike/ spd/ sad/
ipsec/ dnsrd/ ddns/ dhcpc/ ipreasm/
dhcpd/ dhcpr/ rtrid/ macdatabase/ cmgr/
scep/ ldap/ syslog/ mesgthrt/
ocsp/ domain/ wan/ snmp/
lxos/ interfaces/ webproxy/ http/
FVS338: /config/sys>
setzone - sets system time zone. Usage: setzone +/-hh:mm abbrivation <-dst [set/reset]>
settime - sets system time. Usage: settime mm-dd-yyyy hh:mm:ss
time - displays system time. Usage: time
reboot - Reboots the system. Usage: reboot
facdefault - Sets factory defaults. Needs reboot
boxtype - Displays the box configuration type(SOHO(SME)/MTU). Syntax: boxtype
syslist - Displays all the system variables USAGE: SysList
syscontact - sets the system contact person info :USAGE SysContact <CONTACT ADDRESS>
sysname - sets the name of this node :USAGE SysName <name string>
syslocation - sets the physical Location of this node :USAGE SysLocation <name string>
domainname - sets the domain name:USAGE domainname <domain name string>
startcap - Starts packet capture :USAGE startcap <IfaceName> [-c NoOfPackets] :Ex startcap ixp0 -c 20
stopcap - Stops the packet capture :USAGE stopcap
FVS338: /config/sntpc>
sntpenable - USAGE: sntpenable [-i <timezone Index>]
1 - UK,GreenWich,Casablanca,Monrovia (GMT).
2 - Eniwetok,Kwajalein (GMT-12:00).
3 - Midway I., Samoa (GMT-11:00).
4 - Hawaii (GMT-10:00).
5 - Marqesas Is. (GMT-9:30).
6 - Alaska (GMT-9:00).
7 - Pitciarn Is. (GMT-8:30).
8 - Pacific Time ..US and Canada (GMT-8:00).
9 - Arizona (GMT-07:00).
10 - MountainTime(USA)(GMT-7:00).
11 - CentralTime(USA),Mexico City,Tequciqalpa (GMT-6:00).
12 - Indiana East (GMT-05:00).
13 - EasternTime(USA),Bogota,Lima,Quito (GMT-5:00).
14 - AtlanticTime,Caracas,La Paz (GMT-4:00).
15 - Newfoundland (GMT-03:30).
16 - Brasilia,Beunos Aires,Georgetown (GMT-3:00).
17 - Mid-Atlantic (GMT-2:00).
18 - Azores,Cape Verde Is. (GMT-1:00).
19 - Europe (GMT+1:00).
20 - Egypt,Finland,Romania,Turkey,Greece,Jordan(GMT+2:0 0).
21 - Israel(GMT+02:00).
22 - Mascow,St.Petersburg,Iraq,Syria(GMT+03:00).
23 - Iran (GMT+3:30).
24 - Armenia, Azerbaijan (GMT+4:00).
25 - Afghanistan (GMT+4:30).
26 - Pakistan,Russia (GMT+5:00).
27 - India (GMT+5:30).
28 - Bangladesh,Russia (GMT+6:00).
29 - Burma (GMT+6:30).
30 - Thailand, Combodia, Laos (GMT+07:00).
31 - China,kuala Lumpur,Singapore,Philippines,Perth(GMT+08:00).
32 - Japan,Korea,Russia (GMT+09:00).
33 - Adelaide (GMT+9:30).
34 - Brisbane,Gaum,Papua New Guinea,Tasmania (GMT+10:00).
35 - Sydney,Melbourne,canberra (GMT+10:00).
36 - Lord Howe I. (GMT+10:30)
37 - Solomon Is., Magadan,Russia (GMT+11:00).
38 - Norfolk I. (GMT+11:30)
39 - New Zealand,Fiji,Kamchatka,Marshall Is.(GMT+12:00).
40 - Tonga (GMT+13:00).
41 - Kiribati,Western Samoa (GMT+14:00).
addservers - USAGE: addservers <Primary Server Domain Name/IP Address> [-pp <Primary Server Port>]
[[-s <Secondary Server Domain Name/IP Address>] [-sp <Secondary Server Port>]]
Public SNTP Servers list:
louie.udel.edu ntp-0.cso.uiuc.edu ntp.ourconcord.net
ntp-1.mcs.anl.gov ntp-2.mcs.anl.gov time-a.nist.gov
time-b.nist.gov time-a.timefreq.bldrdoc.gov utcnist.colorado.edu
time.nist.gov time-nw.nist.gov nist1.datum.com
nist1.aol-ca.truetime.com
listservers - list servers ....
Syntax:listservers
sntpdisable - Disables the sntp client....
Syntax:sntpdisable
show - Displays the Sntp Client Parameters...
Syntax:show
delservers - Delete servers...
Usage : delservers <prim/sec/all> (primary server/secondary servers /both )
FVS338: /config/ip>
route/ rip/
address - address <ifname> <static/dynamic>[if static only:-><-ip <ipaddr>/<mask'bits>>]
[-rip <enable/disable>] [if dynamic only:-><-dfrt enable/disable>,
we need to tell whether DHCP client should add default route corresponding to
the gateway it got from DHCP server]
alias - alias <interface> <ipaddress> [-m mask] [-b broadcast]
up - USAGE : Up <interface>
down - down <interface>
list - list [-i interface] lists all the statistics
stats - USAGE : stats
FVS338: /config/ip/route>
add - add <ipaddr'default> <gw> <mask> <iface> <metric>
Ex: add 172.16.5.0 172.16.1.5 255.255.255.0 eth0 15
del - del <ipaddr'default> <gw> <mask> <iface> <metric>
list - lists all the routing table entries
FVS338: /config/ip/rip>
showrec - To show records: showrec [-name <record name>]
delrec - To delete a rip record: delrec <rip record name>
addrec - To add a rip record: addrec <record name>
<version: 1[for RIPv1] or 2[for RIPv2] or
3[for RIPv2(RIPv1 compatible)]>
<direction control: Tx or Rx or TxRx>
[-auth <authtype: 0(AUTHNONE), 2(SIMPLE) or 3(MD5)>]
[-id1 <authid1>] [-key1 <authkey1>]
[-starttime1 <starttime1>] [-stoptime1 <stoptime1>]
[-id2 <authid2>] [-key2 <authkey2>]
[-starttime2 <starttime2>] [-stoptime2 <stoptime2>]
Note: For Simple authentication use opt parameter [-key1 <authkey1>]
to enter Password
For starttimes and stoptimes:: Time format: <mm/dd/yyyy'hr:min:sec>
Example: -starttime1 6/6/2001'5:30:00
modrec - To modify a rip record: modrec <record name>
to enter Password
list - List RIP list : list [-name <ifname>]
merge - Set Merge on or off : merge on'off
senddefault - Set SendDefault on or off : senddefault on'off
subnets - Enable/Disable subnets : subnets on'of
Posted on Mar 12, 2012
How do I find wps button on Netgear WNR834B
The Netgear WNR834B does not support WiFi Protected Setup (WPS).
You can follow the documentation in the manual to setup WPA-PSK (Pre-Shared Key) and use the key to add devices to your wireless network.
Manual: http://documentation.netgear.com/wnr834b/enu/202-10171-01/pdfs/FullManual.pdf
Jun 24, 2014 | Arris SURFboard SBG900 Wireless Router...
My canon ip1900 is printing with smudged lines how can i resolve this
troubleshoot the problem to canon website and they will lead you to a self diagnosis that will correct your printer
Jun 29, 2012 | Unknown 7 Pk Canon Compatible Pgi-5bk...
How to remove (disable) FVS336Gv2 full VPN access in LAN using CLI?
http://support.netgear.com/product/FVS336Gv2
I would suggest going to the site above and read more on configuring your device. It sounds like your VPN firewall is blocking your browser from accessing the web interface.
Jun 15, 2012 | NetGear Computers & Internet
Netgear rangemax wnr854t setup
Here is a link to the web page containing all the documentation to setup the machine. There are the two tabs you need, documentation and downloads.
Hope this helps.
http://kb.netgear.com/app/products/model/a_id/2619
Nov 06, 2009 | NetGear RangeMax NEXT WNR854T Wireless...
I have a netgear, 54 mbps wireless router WGR614 v5 and can not locate my installation disk. Can anyone tell me where I vcan get the instructions to install it?
This is Netgear Support and the page for the Netgear WGR614 version 5,
http://kb.netgear.com/app/products/model/a_id/2587
1.Software you need:
Click on the Downloads tab.
Now click on the - WGR614v5 Firmware Version 1.09, in blue.
(I would bookmark this page. After you have installed the software, you need to come back, and download the Installation Guide. While installing the software, it is best to have your internet connection closed, and all windows closed. You will then be on your desktop screen.
If you do not have your downloads set to save to your My Documents folder, {Documents for Vista}, this download will go to your desktop screen.
When you see it, double-click right on the file name. The Installation Wizard will come up. Just click on Next, Next again, and Finish. Do not be concerned when it shows you where the file is going. It will be put in the correct place. Don't change it)
2.Documentation: (Instructions for installing)
Click on the Documentation tab.
The Installation Guide is listed at the top of the list
Sep 30, 2009 | NetGear WGR614 Wireless Router
Not able to telnet to my home router (netgear WGR614V9)
You have to have telnet access enabled for all earlier revisions of wgr614. See : http://www.seattlewireless.net/index.cgi/NetgearWGR614#UnlockingtheTelnetCosole but bear in mind that v9 is not known officially to have a telnet CLI.
Cheers,
Mar 17, 2009 | NetGear Computers & Internet
HOW TO MODIFY A CONFIGURED IOS COMMAND AT WORKING ROUTER
What type of router is it? Cisco, Netgear, Juniper?
It depends on who the manufacturer is of the device. Cisco you can either use a CLI to change the router rules table or you can use a GUI to make the changes. Most newer manufacturers have a built-in webpage for modifiying the commands. Although it is not the most efficient way to do it for those who are not very familiar with CLI it might be easier. To check to see if the device has a GUI, open a browser (I suggest IE, most compatible) and enter the IP address of the router into the address bar. If there is a GUI the page will open. Depending if you used a uername and password you might be prompted to enter it now.
Hope this helps you out. Cheers,
Keith
Oct 04, 2008 | Computers & Internet
Computers & Internet Logo
7,840 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
