Can I repair my wash mashine myself?
I loaded it and it started working well, but after about 20 minutes it stopped completely and I cant turn it on eversince. The door is not blocked, I can open it, but the water stays in - it doesnt drain. I checked the fuse - its good. Please help.
    New Friend:
    Problem Solver:
  • 13 Answers
Check the breaker in the house if you haven't already. Use a ohm meter to check your timer and see if it has continuity. If that's not it pull off the shell and check the motor and water pump. Also check for a second fuse behind your control panel some models had 2. If all else fails try calling a used appliance store with it's own repair person or a independent repair person. They will usually tell you how to order whatever part you need and will walk you threw how to instal it.
Posted on Feb 27, 2012
5 Suggested Answers
Anonymous
SOURCE: Front load washing machine
Have you checked the filter, it may need emptying/cleaning out. If you take bottom front panel off you should be able to see it -- I think it's toward the right.
Posted on Nov 28, 2008
Anonymous
SOURCE: Candy CN146
does it spin? It could be the coupler. What type is it?
Posted on Nov 01, 2006
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: washing mashine
If there is a drain issue, sometimes there is an obvious solution. Check the drain hose for any kinks, as well as checking any lint filters in or on the drain hose. Is there a lint sock on the end that's full? Perhaps the drain line itself is plugged. You will want to make sure that the house drain system is not backed up or plugged. Always make sure that the washer drain hose is above the level of water in the drain tub. Some Whirlpool/Kenmore washers make use of a side-check valve near the tub outlet which may get clogged. A standpipe should be at least 1 1/4 inches in diameter, and never seal a drain hose into a standpipe. This can lead to back-siphoning. You also want to make sure that the standpipe is less than 96 inches in height. Pump problems show various symptoms. Sometimes the pump will lock up and seize. If the motor is running, it will continue to try to turn the pump. In the case of belt-driven pumps, the belt may break or burn through. The pulley may shear off. If there is enough tension on the belt, and the motor continues to try to turn it, you may wind up with a seized motor as well. The pump itself may have seized bearings, be jammed by clothing or another object; or the impeller blades may be broken off. The usual fix is to replace the pump.
If you think your pump may be jammed, drain out your tub and remove the hoses. Look inside the hoses and see if there are any obstructions. Feel around inside the pump inlets for anything that may be jamming the pump itself. You can also use long-nosed pliers to feel around inside the pump for any items that may be causing a jam. If you haven't found a jam, and you still believe there may be a jam in the pump, you can completely remove the pump from the washer and inspect it more closely.
Occasionally, transmission gears may become worn, or some other internal part may go bad. Some older washer models have an electric-mechanical shifter. If it won't shift, it's best to call a professional appliance repair person to address this issue. If your transmission is leaking oil, there are really only two options at this point, either run it until it dies completely, or replace it now.
Posted on Sep 27, 2008
reddyanantha
anantha reddy
  • 205 Answers
SOURCE: washing mashine does not drain completely after
mam
there is a filter it will be blocked please clear it then see its draining also check if there is drain pump if its there it should work.drain pump is located at the back of the machine and the filter at front of the machine.
Posted on Sep 07, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: hotpoint Aquarius+ WF740 washing mashine flashing F-05s
  • F05 - Pressure switch jammed on full
  • The pressure switch must be changed.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Posted on Sep 15, 2010
    Its stops when it reaches in 39 minute the function set on cottons what is the problem
    Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Somebody leaned on the buttons of mashine during wash, and it has frozen
    Hi Lisa, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
    If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
    How To Fix Washing Machine That Is Not Spinning or Draining
    Apr 03, 2016 | Washing Machines
    I turn on the mashine programme wool and turned it on but my little one pressed the buttons after it and now there is a key on the display, the button "Start" is flashing but when I press it it...
    Your machine has (quite correctly) operated it's child safety lock.
    Your manual should tell you how to re-set it, however, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and you should be able to start the program again as you would normally
    Jul 19, 2011 | Washing Machines
    Model no wa80b3 samsung washing mashine
    My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
    May 02, 2009 | Washing Machines
    Maytag neptune washer
    Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
    Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
    Hotpoint aquarious wf620
    funny my machine does the same, i have had 2 answers one says to hold both the on off button and start button till it comes out of test mode? well something like that, (didn't work) and another tells me its just the board thats faulty, I do believe myself this can be reset by the right test equipment from Hotpoint (Hotpoint not helpful and i have a Hotpoint engineer as a neighbour), its also most embarrassing as i am a recently retired appliance engineer myself of 20 years, i have also been told its a conspiracy to get an engineer to call out to reset it and charge for doing so (being a computer control machine (not sure myself, these things don't happen - do they) Ps if you get told a cure and it works tell me please
    Sep 18, 2007 | Hotpoint Aquarius WD63 Front Load...
    Kenmore 44072 Front Load Washer help
    my kenmore washing machine has the timer out of time
    Aug 08, 2007 | Kenmore 44072 Front Load Washer
    Candy CN146
    0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
    Nov 01, 2006 | Candy CN146 Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
