SOURCE: i need to reset the drum count on Workcentre Pro
I understand you have a situation to reset the drum.
I am still researching this, I forgot the process, sorry.
But If i remember, this might work.
Press and hold these buttons. Menu, 1,3
Power up the machine while holding them.
If you get a messge that says enter code.
It is either 80, 81, or 82.
You can also try to reset the mother board which will defalt all settings on the machine to factory settings. Menu, 1,3, *.
Hold buttons and power up machine, hold buttons for about 15 seconds.
If the star does not work, try the "#" instead.
Your information needs to be reentered in the mahine via the menu button, speed dials, trays sizes you are using.
You may want to print out a reports configuration first before preforming these funtions.
This machine can print out a table road map to show what available menues can be configured.
If this does not work. Then do not try to enter anything else.
It has been so long, I would have to be in front of this machine.
If you are not sure what you are doing, place a service call on this machine and let the service representative handle it for you.
If your machine has been operating pretty good, and you wish to keep it longer, pay the fee and you will have a much better machine to use.
This is a good machine if you wish to keep it longer.
Good luck.
