My all-in-one printer will not scan
My scanner will not scan
Posted by carolstubbs2 on
Jacqueline
  • 76 Answers
Download free irfanview and once opened under file, click select twain source and your scanner should be there, the picture will scan straight into irfanview for saving and editing
Posted on Feb 27, 2012
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
2answers
How can I use scanner on my printer? my printer says it is a printer, scanner and copier. I do not know how to use the scanner. I put a print under the lid, pressed scanner, but where is the picture/print?...
You need to install the software that came with the printer. Then in the HP program group there will be a number of programs, one of which will allow you to scan. Try all the programs if you do not know which one to use (on my printer I have to use the HP Solution centre program).
How do i scan a picture to go on my computer
To be able to scan a picture from your printer, your printer I suppose has a scan. Connect the printer to your system and power on the printer and system. I also want to assume that the printer driver and scanner software have been install. Face the picture you want to scan down on the scanner bed, lunch the scanner software and save the picture to the folder provided of choose a location to save the picture. If you can see the scan software and you are using windows 7, go to devices and printer and luch the scanner from there or you can click start, all prorams, windows fax and scan.
1helpful
I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
The scanner on my PSC1610 HP printer, scanner, copier is only scanning about one-tenth of the picture and the rest of the picture scanned is black
open the scanner in preview and select all the picture you want to scan by stretching the frame around the picture then scan.
1helpful
2answers
Dell 810 all in one printer/scanner not scanning
scanning is a bit of a trick. You have to have hardware to scan with, and SOFTWARE to receive images. Make sure the scanners imaging software suite has been installed, OR, you can use the scanner manager in windows to scan with. Just select the dell 810 as the "scanner source" and click "scan". that should do it.
1helpful
2answers
Cannot scan
you must be install your scanner driver or scanner software. If you see your scanner properties then you can get scane
Scanning Problems
If you can't run a scan when you manually press the scan button in your printer/scanner, try to OPEN the scanner's software in Start => Programs => then look for your scanner software associated with your printer. When the software is open, try to make a scan from there.
Regards!
1helpful
Photosmart 2575 all in one printer- says "no scanning options "
you didn't instal the printer in you're pc. try to install the printer /scanner driver
2answers
Scaner does not scan
Printer works well, but the scanner will not scan only leaves a black page
Ekse
