Question about OKI C Office Equipment & Supplies
Oki c6100 ghosting
Printer ghosting
5 Related Answers
Anonymous
  • 44 Answers
SOURCE: my printer is not printing
Oki appear to only have made a B6100 model printer, this is actually classed as a workgroup mono printer and only prints in black and white, It is not a colour printer here in the UK. I think the US may have this as a C6100 and I think it is similar to the 5000 series of printers. the user manual can be found at http://my.okidata.com/PP-C6100n.nsf?opendatabase . I would print a Menu Map and check the settings and also check the driver setting is not set to B/W printing.
Posted on Nov 19, 2009
Anonymous
SOURCE: Radio Shack Oki C6100 wont print color - firmware needed !
Hey, I got it worked out so that it will print color. I called OKIDATA and initially they said they didn't know what to do and you needed to go back to Radio Shack. Then after talking to a supervisor the associate gave me the following instructions to download
1 - go to okidata.com 2 - click on "drivers" at the top of the page 3 - select "color page printer" 4 - select "C6100n" 5 - click "go" 6 - on the new page that comes up, on the left side of the page, click "Utilities" 7 - Scroll down to "English Job Accounting SERVER" and download the file (version 3.54) 8 - After the program is installed, open it and click the Printer Tab and "Add A Printer" 9 - Once the printer is found, it should show up in the list on the right of the screen. 10 - Right-click the printer and select "properties" 11 - Click the "User" tab - there should be in the status row something about "disabled color printing" 12 - Double click on the rows that say that and for each do the following:
1 - Click the "Use Restrictions Tab" 2 - De-select "print in mono" and "disable color printing"
Then when you've done that for each row, Click "ok"
And then you should be good to go. It worked on my computer right after that. I'm directly connected via USB and also connected wirelessly through our small network.
Posted on Dec 07, 2009
Jeff Hughes
  • 97 Answers
SOURCE: OKI C6100 has the following error when printer is
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Posted on Mar 29, 2010
ikkenom
  • 10406 Answers
SOURCE: it only prints black and white
Somebody must have followed the instructions:
Print Only in Black and White:
• Click Start > Settings > Printers and Faxes.
• Left click on Laser to highlight.
• Click File > Printing Preferences.
• Click on the Color tab.
• Click on the circle by Grayscale to move the bullet to that selection.
• Click Apply and OK.
to switch from "colour" printing to "black".
So, "unclick" the 'Grayscale' setting.
Posted on May 09, 2010
Anonymous
SOURCE: Oki C6100 Laser Printer drum reset - from Fatal
The instructions below do not apply to my okidata c6100. It does not go to "NV-Ram initial" , after you get to " Engine Dialog Mode" , even if you scroll down.
I bilieve that the okidata c6100 has a different way to reset the drum units.
Anybody can help,
Thanks
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Posted on Mar 09, 2011
OKI C6100 Printer Error Messages: K Toner Empty Y Drum Life
Needs Black Toner and Yellow Drum
Replace both while printer is on
Feb 10, 2011 | OKI C6100n Laser Printer
When I turn on my OKI C6100 I keep getting a
It may not be an actual problem with your printer. The two things that cause most Communication Errors are a failing Printer Cable and corrupted Printer Drivers. Problems in your actual Computer System [bad software, hardware problems, incorrect settings, etc], can also cause communication errors. You can delete your old drivers and download the latest available drivers.Bad or corrupted drivers can cause many problems. "DEINSTALL" [remove] your old drivers/printer first and then reload drivers.
Reset printer and hope it works.
Jul 17, 2010 | Office Equipment & Supplies
It only prints black and white
May 09, 2010 | OKI C6100n Laser Printer
Oki C5500 dont have TC/IP menu, do you help me.
Symptom:
Unable to reach Printer from local network or Printer falling off network and needs to be rebooted before being able to print
Cause:
ecblank.gif ecblank.gif ecblank.gif Resolution:
Install OkiLAN8300e Firmware 4.06 (C5500/C5800) or 4.55 (C6100) update using Oki LPR Utility
Are you on a Mac?
Mar 10, 2010 | OKI C5500n Laser Printer
8. Restart printer.
Feb 09, 2010 | OKI C6100n Laser Printer
My printer is not printing in color its a oki c6100 in only prints in black and white
Nov 18, 2009 | Office Equipment & Supplies
OKI C6100 has the following error when printer is turned on: Replace Image Drum 562:C Drum Life
Try this:
6.Press Ready
Nov 11, 2009 | OKI C6100dtn Led Printer
Okidata C6100 getting an error 391
It means paper jam in the 1st paper tray. Check above the pickup roller sometimes, paper will get jammed in there good.
Jul 08, 2009 | OKI C3200n Led Printer
Service call 980:Error
hola
quiem puede ayudarme a desifar el error 980 de ld oki c6100
gracias
Apr 09, 2008 | OKI Office Equipment & Supplies
47 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
