Question about HP Officejet 4110 All-In-One InkJet Printer
How do i make it my default printer - HP Officejet 4110 All-In-One InkJet Printer
Posted by blrichman on
kenneth njonjo
    Top Expert:
  • HP Master
  • 1,575 Answers
Hi
By right clicking on the printer's icon and select on 'set as default printer'.
If not installed,be sure to set it during setup installations.The 'set printer as the default printer' will appear before full installation.
Posted on Feb 27, 2012
Error 5
If no default printer is selected, or no printer driver is installed, Printer Error #5 is displayed.
Select a default printer in Windows by going to your Control Panel > Printers. Highlight your Printer and go to File on then Menu Bar and choosing Set as Default.
If the correct printer is already set as the default, and you get Error #5, try setting another printer as the default printer. Then select and set the desired printer as the default, and reboot the machine. This sometimes clears the problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 15, 2013 | Canon PIXMA MP150 All-In-One InkJet...
When I press print, it shows up as my default print is my fax. How do I change the default printer to be just the printer instead of the fax?
In windows Vista or 7:
  • Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  • Right-click the printer you want to use, and then click Set as Default Printer. A check mark is displayed on the printer icon to mark it as your default printer.
  • In windows XP:
    • Open Printers and Faxes; click Start, click Control Panel, click Printers and Other Hardware, and then click Printers and Faxes.
    • Right-click the printer you want to use as the default printer, and then click Set as Default Printer. A check mark appears next to the printer icon in Printers and Faxes.
    Hope this helps!
    Mar 17, 2011 | Serif Computers & Internet
    I want to make my wireless hp office jet 4500 my default printer
    1. Click on the Start menu and click on Settings, then Printers.
    2. 2
      A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
    3. 3
      Click on Set as Default.
    4. 4
      To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
    Read more: How to Change the Default Printer ' eHow.com http://www.ehow.com/how_6097_change-default-printer.html#ixzz1BoplOTlM
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Jan 23, 2011 | Dell Inspiron Mini 10 Notebook
    How to set printer as default
  • Click on the Start menu and click on Settings, then Printers.
  • A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
  • Click on Set as Default
  • To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
  • Read more: How to Change the Default Printer ' eHow.com http://www.ehow.com/how_6097_change-default-printer.html#ixzz14tGsLTEN
    please leave feedback if this helped you :)))
    Nov 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
    Trying to copy a document. I'ts 8.5 x 11. It's only copying the upper right corner of the document. Can't figure out why. Help.
    Reset the printer to default settings.
    1. Press Setup.
    2. Go to Defaults.
    3. Go to Set Defaults.
    4. Select Use Factory.
    5. Hit Ok to reset the printer to factory default settings.
    6. Reconfigure the printer with the printer settings (Country, Time, Date, etc.)
    7. Try copying.
    NOTE: Wireless connection won't be affected when resetting printer to default settings.
    Oct 12, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
    Default printer keeps shifting from the one I
    The best alternate is to keep the other printer disconnected while not in use...leave you default printer connected and marked default...
    Jul 10, 2010 | Dell Computers & Internet
    Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
    Hi there can only try and I hope it will do the job for you.
    Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    or
    2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
    Or try
    Reset Factory Defaults on the Dell™ 962 Printer
    To reset factory defaults on the printer, perform the following steps:
    1. Press the Mode button several times until the Copy LED is lit.
    2. Press the Menu button until Set Defaults is displayed, then press the Select button.
    3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
    4. Enter the time, date and language, the press the Select button.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
    How do I set up Canon 8500 printer defaults in computer? I print manuals as needed that require 2 sided,colored covers then stapled. There used to be a manual default to select but was erased accidently.
    hi there,
    You can change the default printer to any other printer that you have connected to your computer. This will simplify your printing tasks, since you can select the most frequently used printer to be the default.
    2. A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
    3. Click on Set as Default.
    4. To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
    Hope this initial info/idea helps.
    Apr 24, 2009 | Office Equipment & Supplies
    Default status
    SET YOUR PRINTER AS DEFAULT PRINTER
    GO TO START - CONROL PANEL- PRINTER AND FAXES.
    CHOOSE YOUR PRINTER RIGHT CLICK IT SET DEFAULT PRINTER .
    THEN OK
    U CAN GET PRINT
    Apr 01, 2008 | Lexmark X1150 All-In-One InkJet Printer
    Zebra LP2824Z Staying as default printer
    When a new user is created you must change the default printer by adding the correct printer or you can get somebody with admin rights to uninstall the printer on the default account and it will not print to this printer
    Jan 30, 2008 | Zebra Printer 140-751-00000
    HP Officejet 4110 All-In-One InkJet Printer Logo
    23 people viewed this question
    efs_perpends
    efs_perpends
    Muntejaya Ginting
    Muntejaya Ginting
