Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Bizhub C35 misfeed error
Misfeed no paper found error message won't go off
  • Anonymous Jun 18, 2015
    Here is a link to a video that shows some common problems that will cause the misfeed detected message when no paper is found.https://www.youtube.com/watch?v=Sbo0gon8...
Mark Robinson
    New Friend:
This video will show some of the most common causes for Bizhub C35 misfeeds
https://www.youtube.com/watch?v=Sbo0gon8EIY
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_3d8ef710fe85c567
Posted on Jul 13, 2015
5 Related Answers
Anonymous
  • 167 Answers
SOURCE: misfeed and PDF failure
Thewre could be even a small piece of paper stuck. Try looking even closer, and even open a close the access lids to reset the triggered switch. Even a minute pice of paper in the wrong location can cause a sensor to be triggered and until it is reset it will not work.
Posted on Apr 09, 2008
Siskin
  • 6 Answers
SOURCE: Model cf3102 display misfeed detected
We get a miss feed on our when we load too much paper. Try loading a little less. To undo a miss feed from overloading it you have to open and close all the drawers and eventually it will go away.
Posted on Feb 15, 2009
mike roark
  • 158 Answers
SOURCE: misfeed on tray 3 after doing about 4 copies
The one-way bearing (p/n 4030-3034-01)is slipping on the shaft.
Posted on Oct 25, 2009
Testimonial: "The clutch that engages the pick-up roller is defective and needs replacement."
Marius Chiriac
  • 242 Answers
SOURCE: Km 200 Paper cannot pick
please check if the pick`up rollers are dirty, if so clean them with Platenclene, and check if they are spining, if not call for a tech because one or more clutch`s are faulty.
Posted on Jun 03, 2011
Ty Schmidt
  • 118 Answers
SOURCE: bizhub C35 Will not automatically select the #1
its probly because the tray attributes are off.. check to see if the trays have the exact attribute you are printing... if not then change them
Posted on Oct 31, 2011
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
Will not pick up paper from normal tray 1 but does pick up paper from larger paper tray 2 despite having error message that tray 1 is empty, it also has a duplexer fitted. If you put paper in tray1 it...
check the tray one paper empty senor blow out with air is the paper acturator broken that the device that would lay on the paper when its out of paper the sensor will drop far enough to tell the printer tray one is out of paper miss feed are the rollers are dirty and or need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 14, 2018 | Konica Minolta magicolor 2490MF Laser...
REMOVE PAPER MISFEED
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe you knocked one off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I have a Ricoh Aficio AP410N printer and it displays a message that says "remove misfeed internal path" error message. I checked the paper path and there is nothing there. I checked the manual and there...
Did you take out the toner cartridge and paper trays and open all the covers to try to find the misfeed? If there is really nothing there, you can try turning the printer off and back on to see if it clears itself.
Oct 06, 2009 | Ricoh Aficio AP410N Laser Printer
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Misfeed and PDF failure
Mar 31, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
1,672 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
