I have a Onyko TX-SR303 5.1 Receiver. It has been fine for the last 7 years, no problems. Today, the only speaker that is omitting sound is the left front speaker and the sub-woofer. All speakers however work in the DVD Full Mono. All other listening modes seem to be running out of the left front speaker. I'm thinking maybe to reset the receiver somehow. Not sure what to do.
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
SOURCE: Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
SOURCE: i have an onyko receiver
have you ckeck the tv config??
sometimes u need to select in the tv menu, in audio option to have continue output, otherwise when you turn the volume up in the tv the amplifiers sounds more, have you try this??
or check the cable maybe is damaged.
Good Luck
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
SOURCE: One speaker only works in Mono mode
I would be checking the set up mode , you might have it set to left or right channel only , but in mono mode both speakers will come on through one channel
