Can you make the manual clear?
Hi
Download the manual from the link below.
http://www.insigniaproducts.com/cms/documents/NS-DV4G%20UM%20EN_SP_FR.pdf
Hope it helps.Thanks!
SOURCE: i lost my software cd
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your mp3 files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. [email protected]
SOURCE: tengo un reproductor insignia NS-DV2G
Si es una buena pregunta porque el driver de insignia esta configurado para que trabaje mejor con un programa de musica especifico (puede trabajar con WMP pero con algunos bugs) este aparato hecho por una afiliada de Best Buy usa Rhapsody si tienes Windows 98 click aqui para el programa
http://www.insignia-products.com/skins/Skin_1/Topics/Drivers/RhapsodyBestBuy3.exe
Si tienes Windows xp o vista cliquea:
http://insignia-products.com/skins/Skin_1/Topics/Drivers/RhapsodyBestBuy4.exe
Avisame si pudiste resolverlo de esta manera, estamos para servir.
Recuerda dejar buen feedback
Moises
SOURCE: I was given a used ns-dv2g insignia mp3 and
You may reset the unit by inserting a pointed object, such as a paper clip, into the reset port on the bottom of the unit. A copy of the owner's manual will help identify the location of the port. I hope this helps.
SOURCE: I bought a refurbished insignia NS-DV2G and it
You can find drivers and other useful downloads here.
