Bose Wave System CD Shell System consisting of Radio with single disc player and triple cde player add on. About six years old.
This can often be solved by opening the cover and blowing on the optical head to displace dust and any debris that is fouling between the optics and the actuator that controls the head position. It isn't fool proof but will fix perhaps 40% of units. Take a can of air duster (aerosol blower) and blow the little pick-up form the distance of about 1 inch. It will bounce around in the wind but don't blow to hard. Give it a gentle blast and then try the player. If it doesn't work then try again this time but blow harder.
SOURCE: Bose Wave System CD does not eject
Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
Hope it may helps;
SOURCE: I have a bose acoustic wave,single disc model
Had the same problem. Mine the cd drive got out of alignment. Sorry to say the fix is to have it replaced. BOSE will do this for about $150. Typically this includes the one year service agreement, a full system "tune up" and a one year warrenty.
Call BOSE and they will take care of you.
SOURCE: I have a Bose Wave Music System with add-on 4 cd
I had a similar problem. No discs would play and sometimes they would not eject. I solved my problem with the crevice tool on my vacuum cleaner. I vacuumed out all the openings on the unit, especially the cd slots. This discs now play and eject.
SOURCE: I have the Bose Wave
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence the rejection but the best is for cleaning manually the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is very high.
SOURCE: My Bose Wave radio/cd won`t play cd`s anymore. The
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
