Question about Exercise & Fitness
Location of magnets
Where is the location of magnets
Posted by Michael Penassi on
Tom
    Sergeant:
  • 314 Answers
I've worked on one that had magnets in the handles where they meet at a central point, where the counter is mounted. The counter must be disassembled to see them.
Posted on Feb 27, 2012
Craftsman 5600 watt generator AVR Location? It does not appear to be inside the cover of alternator.
The most common cause of portable generators failing to produce electricity is from the loss of residual magnetism.
Generators work by moving electrical conductors through a magnetic field. Your generator does not have magnets. The magnetic field is created by taking some of the generator output voltage and converting it to DC and feeding it to a coil to make an electromagnet.
When there is a small amount of magnetism left over from the last time the generator was running, it is called residual magnetism. The little bit of magnetism is enough to produce a small amount of electricity. This small amount of electricity is needed to create an even stronger electric magnet. As the engine turns this magnet moving its electric field, through the stator windings, your generator produces even more power.
When the residual magnetism is lost, the generator will produce no power at start-up. This residual magnetism can be lost naturally from not being used or from the load on your generator being connected when the generator is shut off. It can also happen from running a generator with no load for too long.
Generators need to work and it helps maintain that residual magnetism. When they are running, a load should be connected to it. It helps create an even stronger magnetic field. Before you shut it off, turn off the switch or breaker to disconnect the load. If you shut off a generator with the load connected, it can essentially drain or demagnetize the electromagnet. Try and avoid running out of fuel.
How to fix it:
There are a few methods of restoring a generator residual magnetism
12 Volt Generator Battery Method
Locate the voltage regulator for your generator.
Unplug the two wires that connect to the generator brushes. Normally one is red and the other is black or white.
Connect the black or white to the generator ground battery terminal.
Plug in a light, turn on the generator breaker or switch and start the motor.
Connect the battery +12 volts (red cable) to the red wire on the terminals you removed for three seconds.
Remove your wires and replace the plug. The generator should now be producing power again.
Jul 27, 2018 | Electrical Supplies
Is there a magnetic switch if so where is it located
The Magnetic proximity switch usually will be located just above the keyboard on the periphery of the base unit or on the left side periphery or near the synaptics pad . The simplest way to locate is to move a thin iron piece and see where it gets attracted.
Apr 15, 2015 | ASUS Computers & Internet
Where does the magnet go on a model number ltf2940es
Good Morning Annie, thank you for your post!
Generally speaking, the magnet is located in the dispenser drawer. Double check the drawer and if it is closed, remove the drawer and examine the placement of the magnet and reinstall. If the magnet is missing or defective, the magnet probably needs replacing. However, if the magnet is in good condition and in place, an experienced technician may need to examine the reed switch or main control board.
Nov 12, 2013 | Frigidaire ATF6000ES Front Load Washer
How do rebar locators work?
they use pulse-induction method. coils in the probe are charged by electric pulses, which generate a magnetic field, and when rebar enters the magnetic field the probe can measure how strong or weak the magnetic pull
Jan 28, 2013 | Measuring Tools & Sensors
How does a compass always point to due north?
"Due North," by definition, is the direction towards the earth's north pole; or, visually at night, towards Polaris, the north star. Therefore, compasses generally do NOT point towards due North but, rather, point towards "magnetic north," as the other responder described, which is a variably located at some distance from True North, depending upon where the north-locating compass is situated on our planet. In most circumstances magnetic North is close enough so that people are willing to accept it as North in general terms. However, depending on your location, and upon seasonal changes caused by Earth's wobbling rotation (called precession) true North can be many degrees off from magnetic (from your compass's) North. In those cases true North must be determined using declination charts, which will tell you how many degrees to add or subtract on you compass in order to determine true North by the Magnetic North your compass is pointing to. For example, if magnetic North is 10 degrees west of true North at your compass's location (that is, your compass is actually pointing 10 degrees to the "left" of North), then you would correct by considering the +10-degree bearing point on your compass dial as True North--and, likewise, add 10 degrees to any bearing line you happen to determine using your compass. You have one other way of finding True North, which is celestially, by sighting towards the Pole star, aka Polaris, aka the North Star...that is, providing that the sky is UNcloudy and unsunny enough for the star to be visible. Of course, that only works for those located in the morthern hemisphere. Those south of the equator have a "south pole" star but it is not as accurate as Polaris in the northern hemisphere.
Jul 09, 2012 | Camping, Backpacking & Hiking
Magnet fell out of the soap dispenser and now the washer will not fill with water
The magnet needs to be located on the right side of the dispenser housing it is there so the machine knows the drawer is closed. The link below will show the location of the magnet which is part number 51 near the bottom of the page.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0503093-00001.png
Apr 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Magnet location on flywheel of a tecumseh 4 hp on a Ariens snow b
what is going on with the magnets on flywheel or are you talking about the magneto ( coil)
Jan 13, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Toaster button does not latch.
The buttons latch is actually an electromagnet that is engaged and disengaged by a small timer located on the toasters circuit board. The most likely reason why the button will not stay latched is a bad connection to the magnet. Unplug the toaster and open the right side panel by removing the machine screw located on the underside of the toaster. You will notice a pretty simple circuit board with 2 (usually red) wires leading to the magnet. If you have trouble locating the magnet, push the "toast" button and watch out for the component it butts up too. Because the wires attached to the magnet are soldered firmly to the circuit board, the poor connection is usually at the magnet. Gently push the wires towards the magnet to ensure a good connection. To test, plug the toaster in, being sure to remove any tools or loose components from the toaster, and push in the button so see if it latches. If it does latch, open the door to disengage and unplug the toaster before reassembling. If it does not latch, you may need to replace the magnet.
Jan 11, 2010 | Black & Decker TRO210 Toaster Oven with...
Magnets in the wall
magnet can affect color of your screen you need to relocate either your tv or the speaker. you can also remove the pink tinge in the upper corner of your tv by USING A MAGNET, how? by putting this magnet to the affected area then drag going out of your casing. prior from this you need to relocate your tv or the speaker to solve tour problem
Jan 01, 2008 | Toshiba 32A40 32" TV
Magnet
if it's a small rectangular magnet that appears, in our case, fell out, when you add detergent, softener, etc...the magnet goes on the right hand bottom corner of the drawer face, straight up and down, not sideways. this is evidently some type of sensor allowing the washer to start. we had an error code of "ddo" when the magnet fell out.
Sep 04, 2007 | Frigidaire GLTF2940ES Front Load Washer
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
