There do not seem to be any screws holding this door knob together. Is this right?
SOURCE: changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
SOURCE: Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
SOURCE: How to install kwikset door knob with lock
Are the holes in the door? Are you replacing the old lock? Need to know these things, or I will be typing a bunch of stuff you don't need. Most doors come pre-bored. If not, you need 2 bits, One is 2 1/8 inch cup bit, the forstner type is a lot more expensive, and a 1 inch paddle bit, again, the forstner bit is expensive. Measure up the door app 39 inches, unless there is a lock rail on/in the door, then measure to the center of that. Then on the inside of the door, measure back 2 3/8, most locksets now are adj for 2 3/8 or 2 3/4, you can use either one. You can drill either hole first, To drill your one inch hole in the edge of the door sighting along both sides of the door with your eyes crossed so you can make sure you are going straight, you don't want to bust through the side of the door. Then get the big bit out and drill from the mark till you just come through the other side, then back it out and drill from the other side so you don't tear out the hole. Your 1 inch hole should be all the way into the big hole.Then get you chisels, the sharp ones, put the plunger in the one inch hole, nice and straight, then mark the outside with a sharp pencil, cut the line with the chisel then cut out the waste about 1/8 to 3/16 deep, make sure it fits nice and tight, Predrill the two screw holes, or you will split the door.Get the lockset out, the key to the outside, and the button on the inside of what you are locking. Line up the holes, you might have to spin the button to get them to line up, then put in the 2 long screws. Mark the jamb with the striker, To get it right, put the striker on the door, hooked into the latch, mark the edge of the door with a pencil,then put the striker on the jamb, backwards, to the line you just marked, then out line it, use your 1 inch bit to hog out the middle nice and neat, cut the rest out the same way with the chisels, predrill the holes, you should be all set. OH the deadbolt? You didn't mention that, it goes the same way as the lockset, only the hole is smaller, 1 1/2, I think, you will have to check that. Now you know why people call carpenters.
SOURCE: exterior key for deadbolt just turns around and around.
It sounds like the exterior tumbler is bad, it is less expensive to just replace the whole deadbolt than to have the tumbler repaired.
SOURCE: Kwikset SmartKey Error in Changing Key to Lock
Your out of luck this new design is terrible once it locks up and no keys turn it, the lock is done you will have to replace it use the traditional pin tumbler style kwikset and it can be rekeyed unlimited times by a locksmith with or without a key.
