British Telecom Freestyle 2200 Trio Cordless Phone Logo
Question about British Telecom Freestyle 2200 Trio Cordless Phone
How to fix time and date on freestyle 65 - British Telecom Freestyle 2200 Trio Cordless Phone
  • Anonymous Feb 26, 2012
    how to chose the day of the week then date and time
    for BT freestyle 65 phone
1helpful
My htc freestyle keeps changing the order of my texts. it puts all texts ive sent on top and ones received on the bottom, how do i change it?
try going to menu, settings, date & time, and make sure the information is correct where it says "set date" and "set time." if either is wrong, enter the correct information. that should fix it.
what happened is your phone thought you were sending a message earlier or later in time than you actually were, while whoever you're texting was sending messages on time. soooo all of your messages end up clustering at the top or bottom depending on if your phone's date & time is set early or late.
6helpful
How set date at 15300 crono
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all FREESTYLE watch manuals.Rate me, please.
2helpful
2answers
My freestyle model 798 is contantly resetting itself back to Jan. 1 12 am. Is this a battery problem?
No, this is not a battery problem. Use your users manual and read how to reset time and date.
How to set up answering machine to correct time and date as my bt freestyle 750 tells the wrong day and time on messages.
I went on line and found the instruction manual and took it from there. Many thanks for your help anyway.Regards.
8helpful
Can't set the time!!!!
the instruction aren't much help either. this was a watch they discontinued pretty shortly after they released it. poor instructions and poor usability. great watch company though. this one was just a dog.
this was taken from a page off amazon: "Try to use the following for setting.
Press/hold with the upper left button until LIGHT OFF on the display.
Use lower left to select hour, min, date........
Use upper/lower buttons for adjust hour, min, date......
Press upper left to exit setting."
it worked for me. i have several of their watches, but like i said, this one was one of their "dogs"
10helpful
4answers
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Top British Telecom Lands Phones Experts
NADARK
NADARK
Lawrence Oravetz
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
