Question about Samsung CLX3175FN AllInOne Laser Printer
Samsung printer unrecognized by PC
I can fax and copy, but the error on the USB device list shows "unknown device". I have tried different cable and tried hooking up to another laptop with the same result. It has worked for over a year and now suddenly it is unrecognized???
Posted by mark21739 on
  • mark21739
    mark21739 Feb 27, 2012
    I've tried that and still the same error.
  • mark21739
    mark21739 Feb 28, 2012
    Yes I've tried reinstalling driver several times. No luck.
Jacqueline
  • 76 Answers
You need the driver for it for some reason it must have been uninstalled http://www.samsung.com/us/support/owners/product/CLX-3175FN/XAA#
Posted on Feb 27, 2012
  • Jacqueline Feb 28, 2012
    Have you right clicked the un recognised printer in hardware devices and told it to update driver selecting the driver you just installed?
Unknown device name
Dear Dzejna
Pl. connect the USB cable to the port(port mounted on system mother board.) at the back panel of the desk top pc. Try to implement maintenance operation fro the system program. follow the steps, if its display (Say USB not connected of device not connected) Then there is a problem with Main Board of the printer and its need replacement. (try with other system.
If your desktop has replaced mother board for any hardware cause then it also happen the printer main board gets damage th usb port.
Thanks.
2answers
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
"DOWNLOADING APPLICATION LIST" WHAT DOES
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
Hello! I turn on the printer with USB data cable atached to my pc and the Ready led is on. I installed the printer driver from lexmark support site everything beeing ok until now. I try to print from my...
Please try to switch to another usb port or try using a different usb cable. try to unplug and replug the cable and check if the computer was able to detect the printer.
For further assistance please contact Lexmark Technical Support
6answers
""I can't get my scanner
If reinstalling the drivers doesn't work. Try manually adding the device.
1. Start>Control Panel
2. Under Hardware and Sound click, Add a device
3. From there you should see your Printer/scanner. Go thru the prompts and it should be able to find and install the drivers from manufacturer site
When I upgraded to Windows 7 yesterday, my Canon laser multifuncition printer doesn't print. It shows up as an "unknown device" in the device manager which lists it as a...
Don't believe everything they say as Windows 7 does have some bugs to be worked out. Take out the printer program completely and then download the program with windows 7. Windows update should fix that for you by plugging in the device after you take it out. You can download the correct driver from the canon site if needed.
Uknown device Error - Canon PIXMA M180 All-In-One
just unistall the usb printing support from the device driver then you you restart then you put the printer cd in the rom and try, post your comment
12helpful
7answers
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Samsung CLX3175FN AllInOne Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
Joaquim Martins
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
