Question about Cuisinart GRID8PC Griddler Adjustable Temperature Controls Nonstick Cooking Surface Removable Cooking Plates Selector Knob Floating Hinge
Cuisinart Griddler won't cook pancakes
We set the Griddler to 350 degrees, just as we used to set our electric frying pan. We waited for the green light before starting to cook. However the pancakes wouldn't brown. We tried increasing the temperature to max, but still no browning, just sort of drying out. Technically you could say the pancakes were cooked, but they didn't look cooked.
Posted by nreynolds509 on
1 Related Answer
kebah
Angel Joseph Jr.
  • 684 Answers
SOURCE: what setting should I put my cuisinart griddler on
You can download helpful cooking tips for your griddler at http://www.cuisinart.com
Posted on Jun 10, 2011
What tempt should pork chops be cooked at
You should cook them on at least 350 degrees in the oven for at least 30 minutes, depending on the size. Just keep checking them. Frying them is another option if you are more comfortable doing so. That's how I like to cook them.
Mar 18, 2012 | George Foreman GR35TMRCB Indoor Grill
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
I have a griddler that has been used for greasy cooking--looks baked on. How do I clean the griddler? Water won't do it.
The best way to clean a griddle caked with grease is to turn it on and let it get hot. Then turn it off and while still hot, use a non abrasive cleanser (aka Comet, Bon Ami) with a nylon scrubber to cut through the grease. If the griddle does not have a non stick surface, you can get "screens" to work the grease free. This is what is used on professional grills (usually on a nightly basis). If all else fails, most oven cleaners will do a nice job.
Jun 16, 2011 | Vacuums
Looking for a GG-2-PR for a Cusinart GG-2
everyone knows Cuisinart products save time and now they save space, as well. The Cuisinart™ Grill & Griddle has a large reversible, nonstick plate to make it two appliances in one. An embedded heating element lets you evenly grill poultry, meats, fish and vegetables. Not in the mood to grill? Flip the cooking plate and set the electric thermostat to perfectly cook pancakes, eggs, crab cakes or fajitas!
Feb 21, 2011 | Cuisinart GG2 Indoor Grill
How long do you cook and 10 lbs turkey in a oil cooker
To fry a 10 pound turkey, you heat the oil to 350 degrees Fahrenheit and fry the turkey for 2 1/2 minutes per pound or about 25 minutes.
There are some Safety Precautions, PLEASE READ AND HEED!
NEVER fry a turkey indoors or next to a structure (like your house, garage, etc)
DO NOT over heat the oil...adjust the valves as necessary to keep the oil at 350 degrees
You can inject seasonings into the turkey but before you put it in the oil, make sure the skin is DRY!!! Water on the turkey WILL MAKE the oil splatter and you could very well end up deep-frying your body parts as well as the turkey
When you pour your oil into the pot make sure you DO NOT go over the fill line on the pot...otherwise the oil will splash out when you put the turkey in and, once again, you will end up with deep-fried body parts
When the oil is at 350 and you are ready toput the turkey in, make sure you put it in SLOWLY or you will FRY YOURSELF AND HAVE A HUGE FIRE ON YOUR HANDS
Once the turkey is done cooking, take it out of the pot, put into a pan and wrap it with aluminum foil...this will help keep the bird moist as it cools...YOU MUST LET THE TURKEY REST FOR 30 MINUTES BEFORE CARVING IT
I hope this was helpful to you!
Nov 01, 2009 | Eastman Outdoors Grilling
Setting a particular temperature on the noventop.
The best way to do this is to get confection thermostat that is made to attach to pan and will tell you actual temperature you are cooking at
Apr 21, 2009 | GE Spectra JBP78 Electric Kitchen Range
The right knob had come off!
If your Griddler is still under warranty (3 yr warranty), Cuisinart will replace the entire unit for free. They do not replace knobs. (Cusinart knows if your warranty is valid by the serial number engraved in the bottom of your Griddler). You need to call Cuisart Customer Service at 1-800-726-0190 to get your Griddler replaced. You must pay a $10 shipping fee to get the new Griddler sent to your place, and you must return your broken one in the box they send you, and you pay for the return shipping.
Nov 09, 2008 | Cuisinart GR-4 Griddler
Cuisinart GRID8PC Griddler Adjustable Temperature Controls Nonstick Cooking Surface Removable Cooking Plates Selector Knob Floating Hinge Logo
1,949 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Tom Chichester
Harrie
Dennis
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
