Question about JVC KD-HDR1 CD Player
Jvc kd-hdr1 wiring diagram
Posted by kevin whitford on
Jeffrey Cameo
  • 675 Answers
Most wiring now is standard colors....red=ignition(goes to a switched power source...Yellow=battery...goes to a hot all the time(even with key off)...black=ground...white=left front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - ...green=rear left +....green/blk rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Posted on Feb 26, 2012
5 Related Answers
Anonymous
SOURCE: JVC KD-HDR1; How to change the time?
Hold down the SEL button. Click >> for the tuner to change to Clock H and change the hour with the dial. Go to clock M to change the minutes. Then hit SEL button again to finnish.
Posted on Jul 26, 2007
j_del
Jeremy Dellow
  • 1586 Answers
SOURCE: wont keep memory
Most stereo manufacturers agreed on a color-coding scheme for their wiring to keep things consistent. In that scheme, red wires are run to power (ie, the battery) and serve as the ignition-switched power leads (so when the engine is shut off, the head unit also shuts off), black wires are grounds, and purple, gray, green, and white are used for the main four speakers. Blue is an antenna and/or amplifier turn-on wire. Orange is a dimmer wire (for cars with dimmers on the dash lights, this can be tapped in to also dim the head unit's lighting). Yellow wires are typically the memory wires. These feed power to the head unit constantly, regardless of whether the car is on or not, so that memory presets and tone settings are maintained. Your JVC unit should have a yellow wire coming off the back as part of the harness - this would be the one to supply power. You can run this directly to the battery - that way if you blow the fuse in the fuse box that you're considering using, you won't lose your stereo settings as well as whatever feature the fuse was utilized to protect.
Posted on Jul 23, 2008
Anonymous
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
Anonymous
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
josetejas
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
Installing JVC KD-R740BT in 1997 Ford truck, keep getting "miswiring, check wires and reset" message
Check speaker wires. All four speakers must be independent. Means no shorting to chassis.
Sep 25, 2013 | JVC KD-HDR1 CD Player
I need wiring instructions
The user manual is available on jvc.com. Go to home page, click on support, then click on Instruction manual, then type the model number. Download it and save.
Feb 26, 2012 | JVC KD-HDR1 CD Player
HOW DO I HOOK UP MY MP3 PLAYER TO MY JVC KD-HDR1?
if there is an auxillary input on the radio you can plug it in through that, if not you need a fm transmitter to do it... you can pick em up at your local radioshack
Aug 09, 2011 | JVC KD-HDR1 CD Player
Looking for jvc car stero manual for KD-HDR1
http://resources.jvc.com/Resources/00/00/91/LVT1470-002A.pdf
Jul 09, 2011 | JVC KD-HDR1 CD Player
I have a JVC, KD HDR1, How do you set the time?
You can download the instruction manual from JVC's site here. All the details are there.
Jan 31, 2010 | JVC AM FM CD DET FACE CAR STEREO
Can I use a Chrysler/Infinity amp with aftermarker JVC radio?
it wouldn't be advised unless there are rca connections into the amp. these are the same as the inputs in the back of the jvc. It is possible to connect into an amplifier using speaker cable but i wouldn;t advise doing this unless you know what your doing.
May 15, 2009 | Kenwood KDC-MP235 CD Player
JVC KD-HDR1
Hold the sel button, then release. use the right arrow to scroll through the options until you get to clock h.
Use the volume knob to change the hour.
Press the right arrow again to get clock m
Use the volume knob to change the minute.
Aug 31, 2008 | JVC KD-HDR1 CD Player
VAN AUTO HOOK UP KD-HDR1
This radio can not use a common ground. If your speakers are all grounded together you will blow up the amp IC in the radio. The negative speaker wires run at about 6 or 7 volts and so do the positive speaker wires.
Trust me, run new speaker wires, do not common ground any of these speakers
If this was helpful a good rating would be appreciated.
Mar 08, 2008 | JVC KD-HDR1 CD Player
No bass in my car
if it a 6x9 they is no miracle to it speaker blown cheers
Jan 07, 2008 | JVC KD-HDR1 CD Player
No Manual with it? See if there is a download fron the JVC web site.
Jul 16, 2007 | JVC KD-HDR1 CD Player
JVC KD-HDR1 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
