Question about NexxTech (DR30G0) System
The surround sound only works while playing a dvd. How can I get it to play for regular cable and movies throught netflix.?
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 64 Answers
SOURCE: How to get sound through speakers with tv and not just dvds
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
Posted on Jan 06, 2008
Roadhog1169
  • 45 Answers
SOURCE: Nexxtech ESDVD100 DVD player gone bad, how to replace?
You can try cleaning it with a dvd disk cleaner first. If that dont work by a cheap dvd player and run it to the inputs on the back of the surround player.
Posted on May 24, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: The background music of the
Hello
Yes, fortunately this is only a minor setting which needs to be set right. Although i have never worked on this unit before, all you need to do is to have a look on the remote itself.
The problem is that the player is set to play through the wrong channels. Hence, you can hear the background music and sound, but not the voices. This is because the voice is sent to a channel which does not exist.
On the remote there is usually a button saying channel or sound channel...Something in this line. This will enable you to cycle through the sound channels(2.0 ; 5.1 ; 7.1 etc)
If you cannot find this button on the remote, you will need to have a look around in the sound setting menu.
Hope this can be of help.
Kind regards
Andrea
Posted on Aug 14, 2010
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
Surround sound hok up
try using a HD plug in cable that should solve ur problem
Mar 01, 2009 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Jan 06, 2008 | NexxTech ESDVD100 System
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
NexxTech (DR30G0) System Logo
24 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
