Question about Breville BOV650XL 1800 Watts Toaster Oven with Convection Cooking
The Breville BOV650XL will not power on.
I checked the outlet and breaker. I used many different outlets with no luck.
  • Anonymous Mar 14, 2014
    New Friend:
I had the same problem with my Breville B0V650XL. It worked fine at breakfast, then wouldn't turn on the next time I tried to use it. Judging by the comments on this site, this appears be a common problem with this and many other Breville products.
I fixed my toaster oven by replacing the thermal fuse assembly. This part costs $4.39 on ereplacementparts.com. It's a shame that an expensive toaster oven is rendered useless by the failure of such a cheap part.
Replacing the thermal fuse itself is very simple - you'll need a small wiring nut and a phillips screw driver. Unfortunately, getting to the part requires removing the oven cover and about 40 screws. A long, magentic scewdriver is essential for parts of this job. It took me about 1 hour to fix my oven - two minutes to replace the fuse and the rest of the time to remove and replace the oven cover.
Posted on Feb 10, 2013
  • Rick Hartwig
    Rick Hartwig Dec 01, 2014
    Thanks for the help! I was able to buy the part at radio shack and make the repair as well. Yes, 40 screws were definitely annoying, so recommend using an electric screwdriver. I was also able to get to the fuse just by removing the back, so I didn't have to remove the entire outer housing. Thanks again.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
There is a thermal protector fuse on the outside located above the power supply. I replaced it on mine and it's now working fine.
$1.99 at Radioshack
the Breville BOV650XL will not power on. - daba0d9f-44b4-4298-bf08-b4fac0fce5f8.jpg
Posted on Oct 21, 2013
  • Anonymous Apr 21, 2016
    I replaced mine and it still doesn't turn on. I then got a multimeter and tested both old and new thermal fuse and there's continuity so it looks like both old and new fuse are working. Any idea why else my oven won't turn on?? Thanks.
  • Spottymaldoo Sep 19, 2017
    See it it comes on when you bang the top sharply with your hand - this happened to mine and it was one of the two little relays on the internal circuit board. I ordered two replacements from digikey.com the part number is Z2352-ND and this is a 10 amp relay, single pole single throw, rated at 250V and driven by 12V, normally open. The same part will replace both relays and the pin spacing is identical - just a soldering job.
    New Friend:
  • 15 Answers
Hi, it appears that the units have a thermal trip, which when blown doesnt allow current to power the board, locate and replace the thermal trip unit located above the power board, pinned to the outside of the oven shrowd and you should have sucess.
Posted on Aug 19, 2012
  • VegasSmitty Jul 09, 2013
    They must have taken out the thermal, all thats inside mine is a circuitboard and there isn't one on it.
    New Friend:
How do you get the over cover completely off? i've unscrewed a bunch of screws and the cover comes off along the bottom and sides but it's still attached at the front.
Posted on Nov 11, 2015
  • Anonymous Jun 10, 2016
    It appears you have to take out nearly all the visible screws (including those weirdly hidden behind metal plates in the feet) slide the back down and off, then reach in with a long magnetic phillips and remove the screws driven into the front margin of the cover from inside.
  • curt
    curt Dec 06, 2016
    Heres how to disassemble the BOV650XL:
    #1: Remove all screws and feet holding on the outer shell:
    - 10 screws on back
    - 2 screws on bottom along right and left edge
    - 4 feet, 3 screws each. note 2 front feet have 2 screws hidden under rubber insert
    #2: Remove 12 screws on back that hold on the back cover
    #3: slide out the back cover
    #4: using long phillips screwdriver, remove 5 black screws deep inside along edge of control electronics. 2 along top edge, 3 along side edge.
    #5: remove the outer shell by lifting up the back of it and pulling back to release the clips along the top front edge.
    I got the full replacement part at eReplacementParts.com, part number SP0010496http://www.ereplacementparts.com/thermal...
    make sure you use some tool to support the control board while you pull the wire off the lug, and put the new one on. the force required will break the unsupported board if you dont hold it somehow.
6ya staff
SOURCE:
Breville smart oven no heat or convection fan. LCD and controls working and can hear the oven clicking on.
The fan probably operated on the heat... I would tackle the THERMOSTATS, heat elements (at least 2) and/or fuse first.
My favorite supplier, appliancepartspros, struck out on Breville
(never-mind) I'll add a couple of credible ones at the bottom.
Sears parts is a good information source... but very pricey ($$$$) for the EXACT SAME PARTS you can get elsewhere...
If you can determine from your OWNERS papers which part you want to try first... get the operating parameters... and and check with a volt meter (ohms scale... power OFF)... for continuity on the FUSE, heaters & thermostat.
There is a possibility your control board (PCB) is at fault... it seems to be getting scarce... Turn it over and look for a burned/broken solder joint.
http://www.ereplacementparts.com/breville-bov800xl-smart-oven-parts-c-116052_116061_116092.html
In any case... get three prices...
In the event that PCB is the issue I do recommend LOOKING TO SEARS because of their parts support and warranty...
Good luck (finding the FUSE).
Breville BOV800XL Smart Oven Parts
Parts and Accessories
Sears Appliance Parts
Mar 04, 2016 | Breville The Smart Oven Convection Toaster...
Breville bov800xl wont turn on. Reset option?.
If the screen turns on and looks like it's working but there is no heat, then the problem is the thermal fuse. It takes reassembly and a $5 replacement fuse. I replaced mine with one of the same specifications and it lasted a month. I replaced it again with one that trips at a 10 degrees higher setting and it's been good for a couple of years now.
Feb 25, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
My Breville BOV800XL doesn't have any power.
My BOV800XL did the same thing. Of the three parts you mention the thermal fuse is by far the easiest to test and in my opinion the most likely to go out first. Check it with a meter. If you have trouble locating it read the FixYa solution for "The Breville BOV650XL will not power on." Check it for continuity like you would any fuse.
I found replacement parts at ereplacementparts.com. The thermal fuse assembly was $23 when I checked. Or you could just replace the actual fuse portion of the assembly with a comporable fuse such as http://www.mcmelectronics.com/product/NTE8213. Basically you need a 216*C thermal fuse. These can be had for less than $2 plus shipping. Buy a few just in case.
I just ordered my fuses today so I can't report on the success of my repair, but I am confident the new fuse will solve the problem.
Aug 30, 2012 | Breville BOV800XL 1800 Watts Toaster Oven...
Kitchen Aid KCO222OB toaster oven is not powering up
I was able to replace parts on the circuit board (P/N: 128301_timer_pcb) to fix this issue on my KCO253CU Kitchenaid Toaster Oven. R1 was visibly burned. On further troubleshooting, ZD2 was found to be shorted.
Known Failed Parts Replaced:
R1: 47 Ohm 2 Watt resistor
ZD2: 47V Zener Diode
Other Parts Replaced
C1: 1.5 uF 400 Volt Film Capacitor
ZD1: 5.1 V Zener Diode, tested OK but replaced anyway.
See attached photo of circuit board for component part numbers.
John W.
Apr 10, 2012 | KitchenAid KCO222OB Toaster Oven
Elements not heating
Buy a new toaster. Very cheap appliance.
Feb 02, 2018 | Breville BOV650XL 1800 Watts Toaster Oven...
I had a house with old funky wiring. I'm pretty sure it caused me to blow a fuse in my toaster oven. Can you tell me where the fuse is located?
The manual mentions nothing about any user serviceable fuse or reset. "Funky" wiring in your home shouldn't cause an appliance to fail. Wiring that is in poor condition usually results in blown fuses or tripped circuit breakers in the service panel, heat in places it shouldn't happen and of course, fires.
It is very possible that the outlet is worn to the point that it doesn't make very good contact with the toaster's plug and has caused the toaster to fail to heat up. Try removing the toaster to a different outlet and try again. Check the original outlet with another appliance or lamp, etc. to see if it works or not. Also, check to be sure any ground fault outlet hasn't tripped.
If the toaster fails to work as expected in another outlet, there's little you can do to repair without jeopardizing your safety - especially if you're not familiar with appliance repair. These appliances aren't really meant for disassembly - manufacturers don't want to be liable for "repairs" that end with injuries, burns and death so the make them pretty hard to take apart. Even if you are successful, they make even harder to reassemble without it looking obvious that it has been disassembled.
Take it apart if you want - learn about how it works and buy a new one. These devices don't rely on rocket science and the controls are pretty simple - but it is an electrical device and electricity isn't a hobby. Be safe. Be smart.
BTW - I don't want your money - I just don't want you to get hurt.
Goiod luck!
Feb 18, 2011 | DeLonghi AR690 Retro 1500 Watts Toaster...
This toaster oven gets extremely hot
Definitely return it. It has a partial internal short which is appying full power to only part of the heating element causing th excessive heat. No properly working appliance should make the outlet hot.
Jan 18, 2018 | GE Toaster Ovens
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
Breville BOV650XL 1800 Watts Toaster Oven with Convection Cooking Logo
10,894 people viewed this question
Top Breville Toaster Ovens Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
