See internet.
1983 LINCOLN MARK VI Timing Set - RockAuto
www.rockauto.com/catalog/x,carcode,1188323,parttype,5756
1983 LINCOLN MARK VI 5.0L 302 cubic inch V8 : Engine : Timing Set, Price, Add ...Timing Set - 3 Pc.
SOURCE: 1982 loncoln mark VI
The firing order for that vehicle is: 1-5-4-2-6-3-7-8
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathan_3a3c556b4b17d1d2
SOURCE: 1983 Lincoln Continental/Mark VI STARTER SOLENOID WIRING DIAGRAM NEEDED.
the battery cable should be on one post and the fusible links should be on the same post. the other post should be the starter cable only
SOURCE: i have a 1981 lincoln mark VI 5.0 engine i just
The positive battery cable goes from the battery to one side of solenoid.(big nut). The cable that goes to the starter connects to the other side of solenoid.(big nut). Sticking out the front of the solenoid there is 1 or 2 smaller terminals. There should be a single wire (approx. 14ga or 16ga) that breaks out of the harness near the solenoid that has a black "L" shaped "push" on connector on it. Push that connector onto the small terminal on the solenoid marked "S". Hope this helps. Good luck.
SOURCE: My 1981 Lincoln Continental Mark vi speedometer
http://www.mrwhizard.com/ check this site out they rebuild instrument clusters very common on old digital clusters
SOURCE: I have a 1983 Lincoln Mark VI and the electronic
the clusters gauge has a resistor behind it which is at fault
