Garmin iQue 3600 GPS Receiver Logo
Question about Garmin iQue 3600 GPS Receiver
Ique 3600 maps
I am unable to use map source with my IQUE 3600. Map source wants me to unlock the maps for my city select software and the computer will not find the IQUE 3600 in the USB port when I try to connect the device in the Garmin unlock page. I do not have the MapInstall Icon in the Palm desktop software either. I have windows vista.
Posted by Carmelo on
1 Related Answer
chewykay
  • 12 Answers
SOURCE: iQue3600 maps unavailable
You can get City Navigator 2008 CD from your local Garmin dealer. Cost around $100.
It updates via MapSource program and USB connection to IQue 3600.
Do not get "NT" maps as 3600 does not understand "NT" compression
Posted on Oct 08, 2008
1helpful
3answers
My old garmin 3600 Ique has some problems. I
the software for running the maps is not compatible is the cause.
8helpful
5answers
Need a Map Source CD for a Garmin iQ 3600 GPS
Please visit http://www.ebay.com
Search for the needed item and there you are.
rate this solution afterward.
1helpful
2answers
1 iQue 3600 no Installation Disks or anything else.
You can download for free the installation disk software from www.garmin.com. You can also download a base map, but may have to buy maps from Garmin for more detailed maps/charts. You may need the serial number of the unit to unlock the maps, this is on a paper sticker under the gps antenna.
Unable to see map. I can only see lines of longitude & latitude.
I had same problem,even the SD card had maps on it. I did another map install and hot sync, then maps loaded ok.
IQue3600 maps unavailable
1helpful
2answers
Unlocking IQue 3600 maps
Even with the maps unlocked it they can appear to be locked.
There are little known flags to diable/enable the base/detailed maps.
Check that the boxes are checked under the <Map><Options><Misc>
You can select either base or detailed maps there.
Disable both and it looks like the unit doesn't have any maps.
1helpful
Active Sync USB OK but City Navigator won't find device.
Somewhere I read that if you do a soft reboot to the iQue M5 it will connect to the City Navigator. I did this and it seemed to work, although between downloading and uploading I had to do it again. The process of loading map set (entire US) took an extremely long time (about 3 hours). Also, if you try to receive maps, waypoints and tracks from device all at once, it chokes.
IQue 3600 missing disks
The simplest method is to update the software for the Mapping/Data, the one you probably had is sooo out of date!
http://www8.garmin.com/cartography/mapSource/citynav.jsp
City Navigator North America 2008 DVD
MapSource City Navigator North America
(includes access to the whole disk)
Garmin Part Number: 010-10474-00
U.S. List Price: $139.27 (for domestic US market only)
Top Garmin GPS Experts
Marvin
Marvin
Steve
Tom Chichester
Are you a Garmin GPS Expert? Answer questions, earn points and help others
