My blower also seized due to broken fins in the squirrel cage. Do I have to get the entire blower kit or can it be fixed? Do you knw where I can go to buy the cage if it can be fixed. My husband is handy so I am confident that we can fix it if we had the part. Its for a York Diamond # P3URB12N07501E BLOWER PART # 7062-4708
SOURCE: york diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
SOURCE: Blower and ignitor work and then kick off but will
I had the identical problem with my York. Problem was the burners. The heating element would light the first burner but the flame wouldn't move to the other burners. The flame sensor didn't detect a flame on the last burner so the gas valve would shut off. I removed and cleaned the burners then reversed the first and last.
SOURCE: furnace wont light. have replaced heat rod and
Have your gas supplier verify delivery pressure. Too high or low, the valve will lock up. Should be a free service.
SOURCE: gas furnace
Hi check out the pressure switch clean the air filter and check out the fan control see if this is clean
SOURCE: i have a York Diamond 90 furnace and when i try to
The furnace is not sensing the flame. Turn off the power.
There is a metal rod in front of the last burner to light. It is corroded and needs to be cleaned. Its the flame sensor .
take the 1 screw out holding it in to the bar and scrub it with some steel wool till shiny. replace and turn on furnace. all should be fine.
