I did not see it taken off when replacing waterpump
Below is the master help link
provided to go through belt routing diagram:---Timing belt, drive belt,
serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all
types of car models? http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html For water pump replacement i suggest you to check the help link
provided below. click the link below :---- Water pump replacing procedure for all vehicles? http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html HOW TO REPLACE A WATER PUMP http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html ------------------ http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html --------- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html --------- http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html ------- http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html ----------- This will help. Thanks.
Click the link below: ----
How to route Water Pump Belt for 1992 Oldsmobile ?
How to replace Water Pump on Car ?
How to Remove Water Pump?
Where is Water Pump located ?
Install a retaining clip on the tensioner to hold plunger IN during installation.
marking timing chain
Position the crankshaft using the special tool. Then remove the tool.
Crankshaft special tool positioning
Install the crankshaft sprocket with flange facing forward.
Crankshaft sprocket timing mark
Position the left timing chain on the camshaft sprocket. The timing mark on the camshaft sprocket must be aligned between the 2 copper (or marked) chain links.
Left camshaft sprocket timing mark
Position lower end of right (outer) timing chain on the crankshaft sprocket. Align the copper (or marked) chain link with the timing mark on the outer flange of the crankshaft pulley.
Right camshaft sprocket timing mark
Align the chalk mark on the balance shaft with the camshaft timing mark.
Balance shaft bearing caps
some one else changed the water pump and put it back together wit out putting the harmanica balancer s timing marks on time
