No shouldn't have to do this,are you installing part WR51X10101 heater?if so have you ever had to replace the motor board?do this when you're in the freezer go on top of the evaporator coil,look at the sensor or thermistor same thing,it looks like a white bullet part wr55x10025,look at it,if it has a black ring around it you have to change it,ge had problems with these thermistors,also everything on this fridge runs through the mother board open up the back cover and look at the board if you don't have 7 black relays in the board you have to get the newest board in there,this could be taking out your heater, board part wr55x10942p go here look at picture,if you don't have all the relays on left bottom side get a new board if sensor has black ring replace that too.i've never had to replace a heater again on a fridge and not that soon,make sure no wires are shorting out anywhere that could take out the heater
https://www.repairclinic.com/PartDetail/Control-Board/WR55X10942P/4512753?replacedManufacturerPartNumber=wr55x10942
also i have a diagram of the board it shows you what's on the board if you look at j11 and j9 these are the connections for the defrost heater,the j8 is for compressor so if you jump out j9 and j11 the heater will come on and no compressor with the gray wire connector removed from the board.
https://www.flickr.com/photos/zenzoidman/4482598198/sizes/o/in/photostream/
and i have another site that shows you everything about the board that's very helpful
https://www.scribd.com/document/243353634/GE-Electronic-Refrigerator-AC-Diagnostics-Manual
if your board is the older board i would call ge first,tell them what's been happening and i've seen them send parts to people for free or short money,it's worth a call all they can say is no we can't help you or they could help you out, i'd call.can you do me a favor i've answered a few peoples questions and haven't heard back from them only like 2 people out of like 50 can you just let me know you got this and let me know how you make out thanks and i hope this helps you out.that ge diagnostics manual shows you alot of good stuff.make sure all the wires are in good shape that go to the heater,change out the thermistor also there's a t-stat on top of coil i would change out the t-stat and thermistor if something is bad it could be keeping the heater on longer than it should be and short living it,any wire connections that you have cover them with sealant if you have wire connectors anywhere in there put sealant in there so no water can get into wires and check the board.good luck hope this helps you.
SOURCE: ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
SOURCE: GE Side by Side stopped cooling
This sounds like the defrost heater is bad or dead. The refrigerator will not cool because frost is building up on the evaporator coils in the freezer section and the fan can no longer push air past the coils. You will find that the freezer will build up with frost.
If you are brave enough, remove the cover in the freezer and you will see the coils are completely covered with frost (ICE). At this point with the refrigerator unplugged ( remove food). get a hair dryer or heat gun and melt all the frost. You will notice a heating element ( looks like a tubed light) -element will looked burnt out.
Replacing it at this point is easy. Before you start though, try to get the manual for your system and call around for a local appliance parts store to see if the part is readily available.
SOURCE: GSS22WGPD WW GE Side by Side Refrigerator
first remove freezer panel in back and check frost pattern on evaporator coil while ref. is running and evap. fan disconnected. should be totally covered in light frost.
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
SOURCE: My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
