Question about Sony KV-36FS100 36" TV
Sony KV36FS100 - Has sound but no picture and stand by light blinks when TV is off
My TV was working just fine, then for some reason the picture went out, but the sound is still on. I tried to unplug it and let it sit for 4 hours, but then did was doing the same thing. I noticed the red light on the front labeled stand by/timer was blinking 4 quick flashes when the TV is powered on and also when it is off. Do you think the TV needs a new blub/lamp??? Thank you.
    Top Expert:
  • Sony Master
  • 76,204 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 24, 2017
5 Suggested Answers
6ya staff
SOURCE:
ABRsvcs
  • 4234 Answers
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Posted on Jul 18, 2008
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
Anonymous
  • 7 Answers
SOURCE: My Sony KV-32HS420 Trinitron Wega TV will turn on
You have what is commonly known as a shutdown problem. It's an overload in one of the internal circuits. It needs to be looked at by a professional tv reapir person.
Posted on Nov 03, 2009
TODDAS
Todd Hill
  • 433 Answers
SOURCE: screen went black no picture i changed the blub
Check lamp door, check thermal sensor above lamp. Should read zero ohms.
Posted on Nov 11, 2011
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony 53" rear projection tv picture comes on scrambled and small with the stand by light blinking then the lamps go out. Whenever the channel is changed stand by light blinks again lamps come on for a few...
There are 2 types of Sony rear projection TVs, one that has 3 picture tubes inside and other has one lamp to produce light.
Model number is important to identify what TV do you have so let me know exact model number written at back of TV to find problem reason and suggest its solution.
Thanks.
Nov 30, 2009 | Sony DAV-C770 System
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
65" Sony Sound / No picture 10 & 5 blinks on timer/stand by light
A 10 blink code on this model is usually and ic that has gone out on the d board. If your a novice at tv repair call a service center.
May 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
No picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I have a Sony KDL40S2000 and three months out of manufacturer warranty my TV made a clicking noise similar to feedback in a bad sound system and went to black screen. The error was not recoverable and four blinking lights were seen by a technician. I bought the extended warranty from my store, so I was covered. After one month in the shop, the technician brought my TV back today and told me the panel was replaced which would have cost me 1000 dollars if I wasn't covered by the store warranty. I read on another site the four flashing lights can mean a bad inverter. I don't know enough about TVs to tell you if the panel and inverter are one in the same, I just know you need to get it repared if you get four blinking lights at a huge cost!
Dec 18, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KV-36FS100 36" TV Logo
139 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
