Question about Vizio 42 in. LCD TV
How to closed caption on mute vizio
On all of my old tvs (not HD), i have been able to automatically enable closed captions when tv was muted. i cannot seem to figure out how to do that on my new vizio. Does this tv not do that at all? am i missing something? my tv did NOT come with a remote in it, so maybe it is some function on vizio remote?
Jean DeLauche
  • Vizio Master
  • 2,909 Answers
Hello -
The remote control for your Vizio TV probably has a Closed Caption button. Is there a button with CC printed on it? If so, that is most likely the button to press for Closed Captioning.
Posted on Dec 23, 2017
5 Related Answers
Lee2fixit
  • 218 Answers
SOURCE: how do I turn off captions on vizio tv with remote?
With the television on and in tv mode, press the CC button on the remote. It's the button with a square on it. That should get you into the closed captioning menu.
You could also go into the main setup menu and find it there. For more information, here's a link to your user manual for the Vizio L32.
http://www.vizio.com/assets/0/92/94/120/ea3894d0-b0e7-4526-b80e-1dfd9bbd4bdd.pdf
Posted on Dec 01, 2008
Anonymous
  • 14 Answers
SOURCE: I can not get closed captioning on my vizio VO42L
If you are using a HD cable box then this would be setup in the cable box itself.
Example:
With a Motorola Cable box, you would turn it off and press the menu button (with the receiver off and TV on). This will bring up a menu that will allow you to adjust your digital closed caption settings.
If you do not have a Motorola cable box that I would refer to the manual or call the cable company.
Posted on Apr 05, 2009
leethedeuce
Lee A.
  • 4472 Answers
SOURCE: vizio closed caption
Do you have a cable box hooked up to the unit? On the tv it is quite easy. The directions are located on .48of the manual. Here is an exert it from it is located here:
http://vizio.com/documents/downloads/hdtv/VL420M/254User_Manual.pdf
Thank you,
Lee
Posted on Mar 04, 2010
Anonymous
SOURCE: vizio l37 closed captions are garbled.
we have the same problem and we have direct TV
Posted on Mar 15, 2010
jazzy g
SOURCE: I can't turn on closed caption
i can't turn off the closed caption on my VIZIO 47" when watching in HD !! help!
Posted on Apr 20, 2010
How do i get caption only on mute
On newer Sony TVs you press the CC button to cycle through the available settings for Closed Captions (CC): On, Off, and On when
Muting.
However, it looks like your factory remote control lacks a CC button and your TV menu appears to have a simple Off/On option for what Sony calls Caption Vision. If that is the case then you would need to manually turn on Caption Vision when you mute the television. That hardly seems like the solution you're after.
If you had an aftermarket remote control that could record macros you might be able to program it so that when you press the mute button the TV would mute and also turn on Closed Captioning. This would require the proper remote control and some expertise.
Aug 19, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Panasonic viera cc
Try identifying which caption is from the TV and which is from the cable box by turning the TV Closed Caption on and off while you have to sets of captioning. This will show you which closed caption never turns off.
Aug 08, 2013 | Televison & Video
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
Jul 13, 2011 | LG Televison & Video
Closed caption problems
Most sets do not automatically go CC when Mute is pressed--it's a feature on some. They are either on or off and the systems are different for old SD (white on black) and for new digital and HD (control colors, font, and size). I wouldn't want a mute indicator and CC but I do have CC on all the time--yellow on transparent. The NTSC-analog had the captions encoded on a video line (21 22 or 23?). ATSC does not have those wasted off-picture lines and sends it separately. -Ken
Aug 20, 2009 | Sansui 27" TV
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Toshiba TV 32AV502U - closed captioning
if you have satalite or a cable box the settings need to be changed in them for CC
Jan 08, 2009 | Televison & Video
I cannot turn off the closed caption feature
First, see if your tv is muted. By default, cc comes on when muting that model of tv. Also, you can press menu and navigate to closed captioning and turn it off that way.
Jan 05, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Closed Captioning comes on every time i turn on the tv!
Apparently the 2002 Sharp model TV that I purchased has the closed captioning by default if the mute button is engaged. So there is no solution for my particular model, it has been built in this way. The only solution is not to use the mute button and lower the volume instead.
Jan 03, 2009 | Televison & Video
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
Vizio 42 in. LCD TV Logo
675 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
