Question about Video Cameras
How do you disassemble a Sony ccd-trv57?
Camera will not power on at all. Tape tray is stuck in the open position. All of this due to water spilled on unit! Have AC cord. Tried to power on with AC cord, but nothing lit up. Has been in box for approx. 3 yrs. Where can I download a FREE repair manual or schematic?I'm experienced in PC repair so I somewhat know what i'm doing as far as disassemble stuff.
Posted by Tim Barringer on
  • Tony Parsons
    Tony Parsons Aug 31, 2017
    When you have a kit of irreparable parts, sigh deeply, recycle them, replace the camcorder and vow never to spill liquid on any electrical item ever again.
richie46
    Top Expert:
  • Video Cameras Master
  • 12,962 Answers
Unless car is more than 10 years or so old there is no such thing as a free shop/service manual. If you spilled water on unit an did not wat about a week for it to dry out you have toasted the electronics and now that is why you get no turn on. Time to go shopping. Repair not cost effective.
Posted on Aug 31, 2017
  • PukuJA Nov 25, 2021
    I beg to differ Richie46. It is good experience to get into repairing other things besides computers. I am a computer repair tech and also repair cell phones and tablets. I am working on several different cameras all at once here. The cameras are mine and it’s good experience to learn how to take them apart and put them back together and know what each board does. The only way to learn is to replace parts one of the time until you find out what works and what doesn’t.
5 Related Answers
Anonymous
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
Anonymous
SOURCE: "Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Posted on Oct 26, 2008
Anonymous
SOURCE: Sony Handycam CCD-F77 won't power up
Sony F77's are known for bad power supply circuit boards. I have one that powers up enough to eject or insert a tape but will do nothing else. Recently I took it to a repair shop. Paid $30 to have it diagnosed but elected not to pay the extra $164-$215 to have the board rebuilt.
It is difficult to find people who will even diagnose these old camcorders, but the repairman said the shops that rebuild the boards get 10-15 a week because people really like the high quality of this particular model. I paid over $1500 for mine in 1983 or so and may yet decide to have it rebuilt.
The repair shop I took mine to is Westronix in Salem, Oregon.
Posted on Dec 08, 2008
Anonymous
  • 107 Answers
SOURCE: get output from sony video camera CCD-TRV238E
You need a computer with video card capable to take composite or super video input if you have that then the software it come with that video card then you can transfer from your CAM to computer and burn into DVD or HDD
Cheers
Posted on Dec 10, 2008
Anonymous
  • 415 Answers
SOURCE: i can't transfer my video on pc from tape. my
to transfer video from your camcorder to your pc you will need a firewire cable (ieee 1394). only with this cable you will be able to transer video.
you will also need a firewire port on your pc.
if you don't have one then you can buy a firewire pci card.
see this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
Posted on Jan 26, 2010
2helpful
Hi how can i transfer my video files from my sony handycam vision video 8 XR model CCD-TRV57. I do not have drivers for the said unit to be transferred to my PC. Thank you and more power.
I have an old video camcorder. Sony SteadyShot Handycam Vision. Model CCD-TRV57. The screen flashes C 31:23. Can anyone help me with this problem?
When I trun my camera on it beeps and flashes c:32:20
This problem actually related to misalignment of mechanical tape path of cassette loading assembly, please follow the procedure given below:
"Remove the battery or power cable, connect, and perform
operations from the beginning."
If problem persists then you have to contact any expert nearby for the mechanical adjustment of tape loading path assembly because its a bit tech job and can perform by an expert, Let me know if you have any experience along with proper tools then i can describe how to fix it.
Thanks for using fixya.
1helpful
2answers
I have a sony Handycam videoHi8 camcorder, my problem is that it
Try using different tape or a new tape in the Camcorder.
Clean the video heads using the Sony V8-25CLD cleaning cassette.
You may also try pressing and holding the Reset button for 30 seconds to reset all the settings in the unit to the factory defaults.
Good luck!!!!!!!!! !!!!!!!!!
Error messages / Manual useless
have you run a Head Cleaning tape thru it? definite;y try that...run it for 10 seconds at a time
1helpful
Dont know how to play a tape from camcorder onto my tv
just insert the tape in camera and connect yellow to yellow port in camera and audio is white and red on the other side follow the color code on tv back panel or front if u have and put ur tv into AV mode and then play back ur camera tape using playback mode look out for switch with play icont on it to select the play mode in camera u are set watch it on tv u want anything else i am here to help u
pls rate me FIXYA for help
29helpful
4answers
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Tape deck
hit it with a large hammer , if it does not open then ... im affraid its a trip to the sony shop to buy a new one & dont forget you can claim for a new one on your house insurance .... so all is not lost
1helpful
No display at all
these cam's are notorious for leaking capacitors time for a new cam
Video Cameras Logo
Top Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Video Camera Expert? Answer questions, earn points and help others
