Question about Water Heaters
SOURCE: Vokera Linea 28 combi boiler
sounds like you have an earth leak or defective pump winding
Posted on Nov 27, 2008
SOURCE: vokera linea 28 boiler. I am continuously having to re-pressurise
I have a similar problem with this boiler. When CH on, boiler overpressurises, (check relief valve outlet) You will then lose water from the CH loop and will have to repressurise when the CH loop cools. The problem is most likely caused by a loss of air from the expansion tank, which will need re-charged. This is not a big job as it has a standard tyre type valve connection but needs an accurate pressure gauge. Probably best left for plumber.
Posted on Apr 30, 2009
SOURCE: vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Posted on Jun 06, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
SOURCE: worcester 24i combi boiler loseing water from
http://www.plumbnation.co.uk/site/worcester-greenstar-junior-24i-combi-boiler-natural-gas/
Annie, I don't have experience in this boiler , but I found a link that has some information and numbers to get help. Thought I would pass it on and hope it will be helpful.
Posted on Jun 09, 2010
Jan 28, 2014 | Water Heaters
Oct 20, 2017 | Water Heaters
May 26, 2012 | Water Heaters
Dec 21, 2009 | Water Heaters
Nov 08, 2009 | Water Heaters
Mar 14, 2009 | Water Heaters
Feb 20, 2009 | Water Heaters
Jan 31, 2009 | Water Heaters
Nov 04, 2008 | Water Heaters
121 people viewed this question
