This tv has been hooked to a cable box with a hdmi cable and I removed the box to place it on a different tv in the house. the tv won't read the cable channels when hooked directly to the cable wire from the wall. hooked a different tv to this same wire and it reads it just fine. any ideas??
It sound like the tuner was bad. Replace main board will fix it.
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
SOURCE: Vizio gv42L working fine on cable hooked directly.
Reset to factory setting,should work,back to normal,not than ur backlight video board is dying shorting out.
SOURCE: I have a VIZIO LED/LCD VF551XVT hooked up to a
I have this same problem, when I turn on the TV there is no sound. I have cycled through HDMI and off air signal and comp 1, all with no sound. The only way I can get it back is to go in to the menu and change the sound to fixed from variable, then it will pop back on. Since the lack off sound happens with digital tuner on local channel I know it is the TV and not my Direct TV box.
SOURCE: TV is hooked to comcast
You need to select HDMI 2 in tv to get bluray playback picture and sound.
Select HDMI 2 source by either tv remote or buttons on tv itself then tv will show bluray picture.
Let me know if you have additional question.
Thanks.
