I have the same deal here ,Red lights Blinks . i UNPLUG IT AND FOR THE MOST IT POWERS UP AGAIN ,I CRACK IT OPEN AND FOUN A LOOSE PIN THAT WAS LOOSE SOLDERED THE ****** AND IT SEEM TO FIX THE PROBLEM FOR A MINUTE THERE BUT IT WENT BACK TO SQUARE ONE AGAIN.I SUSPECT A RELAY THATS LOCATED ON THE POWER BOARD. ANY SUJESTIONS
SOURCE: Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
........................T.
SOURCE: Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
Repairs Made:
Total Cost to Repair about $10
SOURCE: toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: toshiba 46H84 tv turned off light blinking
Also
or dvd connected.
1The
protection circuit.
Common faults
Check also
SOURCE: TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
I have the same problem, red power light blinks. I unplug it and plug
it back in and power will turn on but once I turn it off, back to
square one again.
When you try and turn on the computer the red power light blinks.. When you unplug and wait it doesnt help at all. The screen wont show at all. You can hear the power turning on (the noise the screen makes) but the picture or noise? how do i know if it is the lamp, and not something else?
