It is printing off the paper as if it thinks there is 8.5 x 11 paper in the tray or as if it wants the paper aligned in the center of the feed tray not to the right.
I have set the paper size within the application and in the print properties. I tried to set the paper size on the front of the printer itself but it only has 8.5 x 11 or A4 for options, I tried both but neither worked
SOURCE: Printing from different trays
this can normaly be solved by going into the printer preferences and then setting the trays manualy in the software. otherwise the printer will automaticaly select the main tray first then move onto the mp tray. sorry if it sounds a bit vague but these options change from printer to printer and have not seen a k850 for a while Hope thyis helps Cops [email protected]
SOURCE: Changing Paper Size
If the blue guide in the back of the tray (called the length plate adjuster) is broken or dislodged, the machine may not recognize what size paper is installed. When the guide is moved, three arms on the right side of the paper tray change configuration. Those arms push against sensors in the machine to tell the printer what size paper is in the tray. You can temporarily resolve this by taping the guide in the A4 position, however you should consider replacing the tray or replacing the guide soon to avoid tape getting into the printer.
Hope this helps!
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
This company is terrible at helping customers. I have the same issue.
