Question about Samsung LN32A330 32 in. LCD TV
LN32A330 The Power is connected and good, the TV responds to the remote but no picture at all and no sound. Red light flashes on the front showing that remote has been pushed but flashed for about 6 times and then goes off. Almost as if it's in sleep mode or power saving, but I see nothing in the book about that. Is it a software problem ?
Posted by mark669 on
  • 1 more comment
  • Anonymous Apr 21, 2009
    Same problem, power light goes on but no picture or sound.
  • Anonymous May 01, 2009
    same, light flashed, but the picture does not come on
  • brecklundin May 19, 2009
    Same thing here...bought this for my mom and suddenly it just stopped turning on. In fact she walked away for a few minutes, came back and it was no long on and would not respond to the remote though the red light is on. Worst part is, just to prevent any potential power supply issues, I also bought her a sinewave output UPS as we can have flaky power here. So, I did everything possible to guard against any power issues...and the power supply (guessing but that seems the most reasonable point of failure, craps out just short of the end of the 1yr warranty. Worse yet the thing was around $800 last year when I bought it for her...once was a time an $800 TV would last 30-40 YEARS...so tired of this freaking treadmill!
    Now I have a about 2-weeks to get it fixed before the warranty expires. Even worse I have to deal with support, which is likely located in some "We Hate All Americans" ditchwater 3rd world country.
    She is in a convalescent care facility, legally blind after 17 eye surgeries and a bigger screen is the ONLY way she could have a bit of enjoyment watching her Lakers. Pretty disappointed in Samsung right now.
    Top Expert:
  • Samsung Master
  • 76,407 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Posted on Nov 13, 2017
5 Related Answers
Bill Heronemus
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
vinhson65
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
tvtek
Duke
  • 1284 Answers
SOURCE: 32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Posted on Sep 11, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: tv isnt powering on properly the red light flashes
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 19, 2009
patpsc
  • 5 Answers
SOURCE: I have a samsung tv hp-s5053, when you push the
I had the same problem and finally figured out what was wrong and fixed it. If the TV is making clicking sound, 95% the problem is the main power supply board (PSB). The easy fix is to replace the new PSB which can be ordered online from $80 to $100 (model # PSPF 501A01A), or you can buy it straight from Samsung for $129.95. If you are a little handy in electronic, knowing how to solder and troubleshoot electronic components, you can fixed it for a little cost around $30. It was $1.77+ shipping for my case, I guess I'm lucky.
I have read and research a lot of info on the internet forums and here is what I learned about this clicking problem. The clicking noise you hear when turning on the TV is the sound coming from the switching relay. It's the power protection circuit which senses a short somewhere in the system and trying to shut it down. The short can also be from other boards connecting to the main PSB, or within the PSB itself. Of course I'm not certified or TV repair man, but if it is something minor and can be fixed by a handyman, I'll try it first. If it is beyond the basic, a major problem or you have no idea about electronic at all, have it serviced at a certified TV repair shop.
For my case, here are the steps I took to troubleshoot it:
1. Unplug all 4 connectors on the main PSB. Use a Voltmeter to check the voltage on pin 10 of CN804-1 (read the print on the board where it said SB 5V), this is the standby 5V supply. If the voltage is low, not present, or spike on and off, the issue is the power supply. If the TV is totally dead after the clicking stage, this stand by voltage should be 0V or spiking up and down. For my case, the Power thermistor is dead.
2. Visual Inspection: Visually inspect the PSB for any damaged component, especially all the ESR capacitors. Look in the back of the PSB to see if all the solder traces are ok, no crack or black stain causing from burned components. If you find any damaged component, replace it.
3. If everything look good on the main PSB, then the problem is likely on somewhere else, may be the Y-board. At this stage, you should consult with a certified TV repair person.
Here is what happened to me:
Symptom:
-First stage: When turn on the TV, it was clicking for less than one minute then back to normal.
-Second stage: After 3 days, the clicking last longer to about 4 minutes then back to normal.
-Third stage: After 1 week, the power button's blue light is flashing when the TV is off. But "might" turn on after clicking for about 8-10 minutes.
-Fourth stage: No flashing blue light, no response. The TV is totally DEAD!
Solution:
-Visually inspected the PSB. Everything look good except I found an NTC Power Thermistor (next to the switching relay) was bad. It was burned and opened. The number on it is SCK 206.
-I checked the stand by voltage at pin 10 of CN804-1. I have no voltage there but a spiked voltage up and down on the meter (no reading). Definitely the problem is the PSB.
-All solder traces and capacitors look good, so I decided to replace the burned power thermistor. The big problem is to find a new part online because there is no match for SCK 206, SCK 206 is not the part number and no one on the online store knows what substitute part for SCK 206.
After a few days searching for the part number, I was lucky to talked to a technical support from a Amethem company which designed the NTC power thermistor and he quickly recognized the Samsung SCK 206. He gave me a substitute part number of a much better quality power thermistor. The part number is SL227R010 (7Ohms, 10A).
When you have the correct part number, you can find it everywhere. The cost was $1.77 each, and I got it from Digikey.com
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&KeyWords=sl227r010&x=0&y=0
I solder the new component back to the main PSB. My TV came back to life. Hope it help for your case.
Posted on May 21, 2011
Samsung UN55FH6003FXZA won't turn on even though the red LED on the front is lit showing power is available. It did have a long delay to turn on, now not at all.
Samsung TV won't turn on + blinking red light (explained fix ...
? 4:03
https://www.youtube.com/watch?v=wEWzYLaKdgU
Aug 29, 2014 - Uploaded by Mysimplefix
(CC) (HD) A step-by-step repair video, showing the replacement of swollen/shorted "electrolytic capacitors ...Missing: un55fh6003fxza
bout 1,270 results (0.53 seconds) Search ResultsSamsung LCD TV LN32A330 power won't turn on - Forums - CNETwww.cnet.com > Forums > SamsungCNETMy 1 1/2 year-old LCD TV model LN32A330 won't turn on by direct and remote today. The red stand-by light is lit, but never blinks and the TV won't power up. A..Samsung UN55FH6003FXZA BN94-06418R Main Board ...www.shopjimmy.com/samsung-un55fh6003fxza-bn94-0641...ShopJimmyThis Samsung UN55FH6003FXZA BN94-06418R Main Board IC901 EEPROM ONLY ... TV won't turn on after being off for 30+ minutes - TV shuts off by itself
Jan 05, 2016 | Samsung Televison & Video
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
Wont turn on
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
Phillips 32" tv stuck in standby mode
thesupply is not responding
take your tv for repair
let them check power supply
semi conductors, transistors, zener diodes, an dfuse resistors, also check the switch contact,
and fuse,
Dec 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Please Help
call a tech your tv needs to to be repaired the problem is in the power supply and related circuit.good luck.
Apr 07, 2007 | Sony KV-27FV16 TV
Samsung LN32A330 32 in. LCD TV Logo
238 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
