Have the older model... paddle is plastic... is this dangerous... does the taste of the plastic get into the bread itself???? thanks
SOURCE: Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
SOURCE: No user manual for a black and decker programmable bread maker
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
SOURCE: I now have 3 Blacker
SOURCE: i need to replace bread maker paddle
Your model number for the all in one pro should be a B1650 (single paddle model)
If that is correct then this is one source for the paddle:
http://www.abtecparts.com/commerce/search/products/?product_id=01XBD42959200&merchant_id=1933
An informationl note about Black and Decker products is that there are replacement parts for anything they make as long as they have no discontinued the model number. Once the model number is discontinued they have aftermarket replacement parts for 5 years only.
(your replacement paddle is starting to show up as no longer available)
The orignal paddle part number is: 429592-00
Here is a 2nd source for the paddle:
(96 in stock)
http://www.radioequip.com/servlet/the-Home-Appliances-cln-Black-and-Decker-cln-Bread-Makers/Categories
Thanks for using FixYa:
Kelly
