Question about HP LaserJet 1160 Printer
Paper jaam give the 20-15 pages then paper jam in the printer and i have change taflon, damage presser roller but Problem not solved.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
If old need to replace all rollers that feed paper - not an easy job
Try changing paper
Once you open the package paper attracts water like crazy and gets very humid and it will jam on regular basis
Try and keep your paper out of humidity
good luck
Posted on Feb 06, 2012
6ya staff
SOURCE:
Why does my printer grab several pages of paper at once instead of one?
The printer when it was cleaned for paper jam might have damaged paper rollers which picks the paper as the gap is increased due to paper pull.You can replace rollers then problem will be solved .
Jul 20, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Adf takes more than one page per feed
Sheet detector sensor has been damaged or bent probably by a paper jam (assume you have set the paper weight in the printer dialogue box to the correct media). Best solution, check the feed path of the paper and see if there are any rollers or grippers bent out of true and try to straighten them gently.
Jul 18, 2011 | Canon PIXMA MP780 All-In-One InkJet...
It wont grab the paper to print
Paper feed problem:
Remove any loose paper in the printer.
Paper jams
85% of paper jams are caused by worn rollers .The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 03, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jam
Dear Sir,
By analyzing your printer paper jam problem,it deffinately due to paper piece or dust particle wrapped to the the printer page roller.So check your printer keenly for any paper piece or any other obstacle disturbing printer roller and clean dust wrapped on printer roller with brush.Then turn on the printer give the page to the printer,care must be taken that page inserted is must be straight.then give the print. It definitely solves your problem.if you have any problem regarding this issue comment your problem with more information,we will glad to assist you.
good luck
thanking you for choosing fixya
Aug 26, 2009 | Canon PIXMA iP1200 Photo Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Paper keeps jamming
try resetting by unplugging and then plugging back in, then make sure no paper is jammed in the rollers...make sure rollers are clean and they are not worn down, make sure your using the right type of paper.
Apr 05, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Paper jam notification after printing one page, no paper jam
try this
alternative :
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper jam problam
no the tefflon is not fitted properly as you again open the printer and clean the tefflons upper side as any of the greece substance is got stuck up on the tefflon to cause this problem.also clean the pressor roller of orange/red colour with the isoprophyl and then slowly rub the liquid with very dry tissue.your pressure roller is perfectly alright as this paper jam problem comes very often after the tefflon is changed if it is not fitted and cleaned properly.
Jul 02, 2008 | HP LaserJet 1010 Printer
HP LaserJet 1160 Printer Logo
55 people viewed this question
Ekse
Thomas F. Schneider
