Question about Toymax Televison & Video
Program brighthouse remote control for viore tv
5 Related Answers
Anonymous
  • 1077 Answers
SOURCE: Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Posted on Jan 12, 2009
Anonymous
SOURCE: Remote control code
Manufacturer: Akai
Code(s): 0032, 0092, 0672, 0702, 0812, 1903, 1935
Model: Atlas 1056
Posted on Jan 28, 2009
bigguy196
  • 6 Answers
SOURCE: Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
Posted on Apr 20, 2009
Anonymous
SOURCE: progamming code for DYNEX t.v. w/ brighthouse cable remote
Do what I did...
Turn on TV
Press TV on the remote(will blink once)
Press and hold setup until tv button blinks twice
Hit 991 tv key will blink twice
Aim remote at tv press power button once
Press the Chan + key over and over until tv shuts off.
Same instructions as the manual
Posted on Jul 10, 2009
Anonymous
SOURCE: Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
Posted on Feb 05, 2011
Remote codes
What is the Brand name to your TV? Is it Viore? If so, try these codes first. 1690,1699,1649,1642. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
2answers
I purchased this funky TV Viore and can't program it to my IR remote control it wont work I have been given several # already and none of the work Model LC26VH56 26" . Can you please help me before I...
sharonc659,
If you have tried the different codes to program the remote to your TV, you can do a power scan to find a code. I have provided a link on how to do the power scan.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
I hope this helps.
Ray Calo
DISH Network
3helpful
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
We can't program the tv with the brighthouse cable
This is a brighthouse problem not a TV problem, if brighthouse won't help you just use the original or substitue remote.
The brighthouse remote may locate the correct frequency using the scan method ask them to send a remote book.
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
We have a Panasonic 1080P Plasma TV hooked up to BrightHouse Cable and a Blue Ray player. We use a Brighthouse remove to control all. We are trying to hook up a Panasonic DMR-E80H DVD Recorder. We are...
If your tv has inputs for many devices you can connect them. You need to simply change the tv input SOURCE to whatever #/type of input you want to view from.
You can use an y remote if programmed properly- that is another issue. programming the remote to control that deviovce but first see if it works right.
if the brighthouse remote can control the tv, change the input or source to whatever the dvd is in, other wise try the tv remote.
make it simple first, then you can try getting the one remote to control it IF it can.
my cable remote cannot control all my devices but does the tv.
Need tv code !
Contact Driectv and they should be able to give you the code or the speed can method to program your remote.
5helpful
3answers
Cablevision remote won't work viore tv
I was able to program my viore tv by trying the code search:
1. Press the tv and sel buttons until the IO button turns red.
2. Press channel up or down until the tv turns off and the press the tv button to lock in the code.
Ps: Be pattient when searching for the code, it might take a while. HOPE THIS HELPS!!!!!!!!!!!!!!!!
2helpful
2answers
Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
I have just acquired an INSIGNIA 32"lcd tv W/dvd and need the # code to program my Brighthouse remote to control this unit. [email protected]
10-1-08
I solved the problem by useing the brighthouse remote procedure to locate the code # appropriate for the Insignia 32" tv, the unit is currently functioning as it should, thanks for responding.
I donot care to signup for your services for future use.
Universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Televison & Video Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
