SOURCE: installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
SOURCE: EMBLEM, ELJER TUB. DO I CEMENT THE NEW TUB INTO THE FLOOR? HOW MUCH CEMENT AND WHAT KIND?
The tub should just sit on the floor, and caulked around to seal out any water. If it as a fiberglass tub, you might want to put some grout under the bottom to help support it.
SOURCE: installing whirlpool tub
If it is a five foot tub, home depot usually carries them, if not any plumbing supply store will have them.
SOURCE: Eljer jetted tub on and off switch will not work
It may seem like a dumb answer but check the ground fault outlet or breaker. Then make sure there is enough water in the tub. It should be a few inches over the jets.
