Got a Pyle PLTAB8 Car Component System installed and its fine, but the lights will not go off even when the car is off. It was installed by a friend who wired it through the under the hood because I have a stock radio....I'm not very knowledgeable about any of this. How can I get the lights off?
Sounds like he did not wire a remote line from your radio to the amplifier, if he put a 12v from the battery to the amp and the remote spot on the amp then it will not turn off, you will need to either wore a toggle switch to the remote so you can turn it off manually or check the back of your radio for a remote line or splice a remote line from the accessory power supply on your radio so the amp will turn on when the radio is on
