Numark ttUSB Turntable Logo
BLSE Posted on Nov 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Records fine. When we reach Step 5-Please wait as the EZ Vinyl/Tape Converter exports your tracks to iTunes we get this message: The file "iTunes Library.itl" cannot be read because it was created by a newer version of iTunes. Have uninstalled and reinstalled everything, but still get the same message. Please assist.
Bill Willard
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Nov 17, 2017
Bill Willard
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
16242
Points
138
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
1 Related Answer
Anonymous
  • 104 Answers
  • Posted on Feb 11, 2009
SOURCE: Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Hello, Since downloading iTunes version 11.05,
You might need to either reinstall the EZ or see if there is an update.
1helpful
1-I'm recorded my music 10-track on step 3 on EZ Vinyl Converter. 2-On step 5 export recording to iTunes take tolong to complete. 3-I'm access iTunes Music library. I see only 3 music track. 4-Can you...
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
I am having a problem recording more than 1 track on my new ION tape express cassette conversion system. I was instructed by ION to uninstall the previous ez vinyl converter software and re-install the new...
I have the same problem and do not know the answer. Was searching here for an answer to my problem. Only a small part, 4 tracks in fact, about 5 minutes from a 30 minutes tape are imported to Itunes. where is the solution because it seemed the computer was recording the whole tape without problem. Where is the data gone. Can someone explain. Nico
9helpful
9answers
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
1helpful
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
36helpful
3answers
Need drivers for my ION Audio USB Turntable
Hello
USB audio turntable can be found on this site: Driver Update. have a nice day
1helpful
Won't Export to iTunes
it is not compatible with itunes 9 call numark and complain
11helpful
4answers
EZ Vinyl Converter produces file that doesn't work
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
1helpful
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
