1998 Pontiac Firebird Logo
Anonymous Posted on Feb 05, 2012
1998 pontiac firebird V6 3800...NO oil pressure and noisey valves. Have replaced oil pump and oil sending unit,claned oil pan,pick up tube and all parts....I dont know what else to do. Could someone please help me????
  • Anonymous Mar 04, 2012
    thanks for your help but ive done replaced everything that i could and nothing has worked. Im thinking the only other thing that it could be is it spun a main bearing.:-(
raj somaiya
Level 3:
  • Pontiac Master 5,370 Answers
  • Posted on Mar 03, 2012
raj somaiya
Pontiac Master
Level 3:
Answers
5370
Questions
0
Helped
3570565
Points
14579
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
1 Related Answer
Anonymous
  • 1118 Answers
  • Posted on Apr 02, 2009
SOURCE: 1998 firebird engine interchange
Is the engine from the bonneville a 3.8 too. If its is it will interchange, Just make sure you use everything off the 98, like all the sensors ect. The basic engines are the same its the add ons that will be different.
1helpful
Where is the oil pump located on 1998 pontiac firebird
its in the oil pan easiest way is to pull engine remove pan and replace but there are methods of removal without pulling motor
Low oil pressure after warmup
Worn cam berings/crank/rod/bearings. Pluged pickup tube in oil pan,worn oil pump,incorect oil. Bad oil presure sender.
Good Luck!
I have the problem of my oil light in the dashboard, when coming to a stop it lights up, when accelerate it turns off anyone knows what the problem is
have a manual oil pressure guage hooked up to check the actual pressure, it its good replace the sending unit, if low, the oil pan should be removed and the oil pick up tube checked. good luck
3helpful
I need to replace my oil pump and i dont know where it is located on my car.
The oil pump is usually located in the oil pan, connected to the pick up tube.
What makes you think the pump has failed, they are pretty bullet proof. Much more common issues are transducer (gauge sending unit) and pressure control valve.
2answers
Oil pressure it is showing 120
The gauge is faulty or the sending unit is on the engine. I suggest to replace the sending unit on the engine since this switch also activates the fuel pump to prime upon starting the engine up
1helpful
NO OIL PRESSURE warning came on suddenly. I stopped the engine and started it after 10 mins. It was running fine until the same warning came back. Dip stick reads full. SOMEONE HELP!
Hi and welcome to FixYa. I am Kelly. I understand your concerns. No oil pressure is one of the worst things that canhappen to an engine.
The can be caused by a bad oil sending unit or a problem with the sending unit wiring.
The really is only one way to troubleshoot this and that is to read the oil pressure with a direct pressure gage. Most of the time that involves installing a direct reading gage at the oil sending unit port and verifying the actual engine oil pressure. If it is normal the most probable failue is the sending unit.
If the oil pressure is really low then the following things have to be checked:
1. Oil pump
2. Camshaft bearings
3. Main crankshaft bearings
4. Rod end bearings
5. Oil pump pick up tube in the oil pan
You can pull a valve cover an watch for oil flow but it is NOT going to tell you the OIL pressure.
The only easy fix is that of the oil sending unit and associated wiring. Everything else requires disassembly of engine parts for inspection of clearances.
Kelly
2helpful
I have a 1998 Dodge Caravan and the oil gauge light dings when I slow down or stop. How can I fix this?
Your oil gage is telling you your engine is showing signs of wear / aging. (Possible wear on the main bearings, connecting rod, and camshaft bearings) Your idle may now be lower than it should be. Or your oil sending unit is failing. Or... the oil pump iself is not performing as it once did. Or the Oil pump pick up tube in the oil pan is clogging up. Have you tired a direct pressure reading of the oil pressure? If the direct pressure gage indicates same as your oil light then everything listed above will have to be checked to determine exactly what it is that needs fixing.
Kelly
2helpful
3answers
I have a 2004 yukon denali with 100,000 mi today my oil pressure indicator went down to 0 and the alarm went off. i took it to my mecanic we thought we could replace the switch, and after that 300.00...
if oil pressure low or no pressure and engine noise recomand replace engine because to find out what worn inside engine u have to take it apart and chek everything by time u do that beter of get rebuild engine with werenty
1helpful
98 Volvo V70 GLT - Oil Pump or Valve Job?
Most common cause of ticking in these is the oil pick-up seals. Remove the pan and replace the oil pick-up tube seal, the two seals for the tube in the pan and the 2 O-rings on the right side of the pan. And dont use silicone to seal the pan back up, because it WILL leak, I highly recommend the Volvo sealant
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
