Check the main output voltage (B+) from its SMPS regulator side. If this voltage is lesser than normal, picture won't fill the entire screen. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts.
SET uses a optical light engine--lamp which is quite hot shines into the engine---blue is first to get the light and heat and is usually first area in the lens and baffles to get damaged(loss of blue leaves red and green which equal a yellow screen.
screen protectors are only plastic covers that protects the screen from scratches and such.
It is not possible to buy a new LCD screen. Since the camera is now Out of Warranty a repair will cost 48 pounds with KODAK.
Always try your extended warranty!.....Probable cause = bad red tube. One adjustment may help---turn down red screen control, located behind technician access panel in front of set.
throw the set away!the part required to repair the set is the optical engine.Zenith made alot of these sets with defective engine assemblies in wich the lcd filters burn,which cannot be replaced.The labor is also silly.Theunitrequires a complete teardown for replacment.You could buy a very nice new set for the repair bill
