SOURCE: I have a Micro Innovations
here is a link of a pdf file manual of your mouse. pls. rate.ty
http://www.mic-innovations.com/files/PD5260LSR-QIG-Back59768_63.pdf
SOURCE: Need Micro innovations OPM-602 manual.
I got one at a garage sale for a buck. Came here for a solution, but still couldn't get it open. I figured it out by breaking it!. Bad for me, good for you. I pried off the black cover and broke off a little tab. I'll explain how it works. Behind the two buttons there is a silver half oval. When you push down on the end of that half oval that's the farthest away from the mouse wheel, it pushes down on a little tab that is part of the black cover, and lets that tab clear a piece of plastic that it clips under. I broke off that tab by prying it. So, push down hard on the END of that little half oval and at the same time slide the black cover back. The mouse uses two AAA batteries. Good luck. That's the solution. Guaranteed!
SOURCE: need battery size and how to open it up without breaking it. I have no manual.
AAs and the end (top where you normally hold it ) just slides back towards the rear. and do the following to reconnect ...(you might as well change the batteries a this time as well)
This is sort of general but it just may
help.
Make sure your batteries are in
correctly.
Make sure the transmitter dongle is in
the USB.
Look on the transmitter, the mouse
and keyboard itself (bottom) for a little tiny
button that says connect or reconnect. Move the mouse about six
inches away from the transmitter and press both the
transmitter and the mouse.
That should reestablish the signal
twixt the two.(or three KB)
