Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
Michelle Posted on Feb 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the WEP/WPA code on a Netgear router
I've tried every number on the box and every number on the router itself. Nothing works
  • Official Brand Answer 3,344 Answers
  • Posted on Feb 10, 2012
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923615
Points
5508
The WEP / WPA security information can be obtained by accessing your Netgear router setup page. You'll need the router's IP address to access the setup page. From your computer, go to Start > Run > type "cmd" (w/o the quotes), hit Enter > DOS black screen appears, type "ipconfig" (w/o the quotes), hit Enter. Take note of the Default Gateway IP address - that is your router's IP address.
Pull up a browser and enter the IP address in the address bar, hit Enter. You will then be asked for your router's Username and Password, enter the required information. If you don't know the info, please contact your router manufacturer for assistance. Once you're in the router setup page, go to the wireless security settings to check the WEP or WPA code.
Should you still need further assistance on this matter, please contact your router manufacturer.
I hope this helps.
1helpful
I have to change my router from wpa to wep and can't figure out how to do it. I have printed out instructions and it tells me to go here or there but when I do the options I'm supposed to cl
All you need to do is , open the setup page of the router and change the wireless security settings.
Go to Wireless section.
Select WEP.
In the key 1 box type 10 digit hexadecimal number.
This 10 digit number will be the password of your network.
I have just bought anew laptop cant get onto internet it wants me to type in security key i dont know what this is can you help me please?
  • If your are trying to connect via wireless from your laptop to the Netgear router, most likely it's requiring you to input the wireless security key(usually it's WEP or WPA encryption).
  • Access the router's setup page by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser(IE or Chrome). On the login use the default username and password(admin, password).
  • After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the Wireless Key. If the wireless security is set to WEP, use the available Key code but If it's WPA, what you need is the passphrase.
Type the Key or Passphrase on your wireless laptop and it should connect to the router.
Trying to hook up wii to internet & received error code 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
1. Are you using WEP or WPA security on your router?
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
4. Check Nintendo's router info for special notes, if available, for your router.
1. Click here to go to our Wireless Router lookup page.
2. Use the drop-down box to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
1. On your PC, click "Start" and then "Run."
2. Type "CMD" into the field that appears to open a new window.
3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
I have netgear wireless-N300router and would like to hook up my wireless hp officejet 4500 to it and also my wireless extender I am having problems conecting them. I can not find the Phasepass code or...
you would have to log into the router itself- Usually netgears are on 192.168.0.1- once you're in the router, go to the wireless setup to get the WEP or WPA keys you need to setup your hardware
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
I have been trying to connect my Wii to my Linksys wireless in my home and every time I try, I get the error code of 51330 with a mention of being unable to connect to the internet. What can I do to fix...
A. Do you have the SSID for your Linksys router as just "linksys"? That name is so common that someone nearby might have set up a new router and left it the same name as well... and your Wii is trying to connect to THEIR "linksys" instead of yours. Try changing the name broadcast by your router to something else, then try connecting using that new name.
B. Be sure you are typing in the WEP or WPA passphrase correctly, it is SO easy to mess up one simple letter in the code and nothing will work. I've gotten dozens of service calls for iPods and games where the customer said their code didn't work, but worked for me when I got there. I know, it's frustrating, just be SURE you have the code 100% correct.
Other reading material from Nintendo is below:
Wii error code 51330 It is unlikely that your Wii console needs any type of repair, as according to the Nintendo Error Code Lookup, the 51330 error code is "usually indicates a problem relating to wireless security."
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  8. If you are still receiving this error code, please click here for assistance.
But if the above information doesn't help correct this problem, then give a call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday) Customer Service number, and one of the service representatives will do some over the phone troubleshooting to determine exactly what is causing this and then talk you through any needed steps to correct it.
I'm trying to log on with my visio tv & I need a wpa key#
To locate the security key please follow the below steps on a computer connected to the router:
1. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
2. Access the router's GUI by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase (or network key).
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless deviceto the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Please revert for any further clarification.
Regards
Anand
5answers
Cannot find wpa code
You can factory reset the router using the small button on the back, hold it in for 30 seconds with the power on to the router. This will clear all settings from the router including the password, so you will need to set up the router again after the reset.
Phone number 01924 835274 need a code for netgear
Following steps will help you out in retrieving the password for the wireless connectivity:-
a)Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
b)In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
c)When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it.
d)Select Wireless Settings from the Setup menu in the left-hand navigation bar.
e)ssid:-any name , channel:-11 , mode:-g and b
f)Under Security Options, select WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
For WEP:-
authentication type should be automatic and encryption strength should be 64-bit.
passphrase:-leave that blank and only select key1 from the list of four keys and in the key1 box type your telephone no. without the numeral 0 in the beginning or hen enter 10 hexadecimal digits of your choice and apply the setting's.
The number in the key1 box will act as the password to connect to the wireless.
For wpa-psk:-
In the passphrase box enter any password of your own choice between 8 to 63 characters which will be
password to connect to the wireless and apply the setting's.
g)You can also follow this link for the help:-
http://kb.netgear.com/app/answers/detail/a_id/112/related/1
4answers
1helpful
2answers
Netgear 834
changed wep to wpa.ipod works great
regards
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
