HP PhotoSmart 7350 InkJet Printer Logo
Genoia Boucher Posted on Feb 04, 2012
Disassemble hp photosmart 7350
Printer has no power
5 Related Answers
Anonymous
  • Posted on Jul 12, 2008
SOURCE: printer cartridge cradle is stuck-hp photosmart 7350
I just had the same problem...and this is what I did to get it working...
Turn off your printer. Open the top. Push the cartridge thingie off to the side (if possible) and then take QTips and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
Should run after that.
geemarie
Gayle Ashbach
  • 876 Answers
  • Posted on Aug 13, 2008
SOURCE: hp photosmart printer 7350
Turen the machine off
Unplug it from the wall
open the paper jam door and gently push the paper roller upward until it clicks.
close the door.
Plug it back in
Wait a few minutes
then turn the printer on and see if the carriage moves.
This is a simple general reset of theprinter and sometimes it will help with this sort of problem. Let me know if it helps or not.
Anonymous
  • 679 Answers
  • Posted on Dec 20, 2008
SOURCE: Getting wet blurry pictures from the hp 7350 printer.
go int the printer utility and run the "clean print head" or nozzles, they are all a bit different
Anonymous
  • 679 Answers
  • Posted on Feb 03, 2009
SOURCE: HP Photosmart 7350 Printer Carriage Cradle is jammed
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Feb 16, 2009
SOURCE: Need to clean hp photosmart 7350 cartridge head
You can try manual cleaning :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
The kodak gloss paper gets jammed in my hp photosmart 7350 printer towards the end of printing photos
You have an HP printer. I highly recommend you use HP photo paper for the best results. This may not solve your jamming problem but it may. HP printers are very touchy as to what photo paper you use.
Cable
Hi vince4763.
Those power adapter can be found in some online stores, but your best bet is on eBay. HERE's one for only $13.00. Can't bet that!
Good Luck,
Mark
Please don't forget to leave a rating based on my solution.
Getting wet blurry pictures from the hp 7350 printer, what is wrong?
2answers
Hp 7350 - lines in pictures
Hi there
your printer conflict with your pc. Please uninstall your printer drivers from the control panel then reboot you pc and then reinstall from printer driver CD. If you don't have a cd then download it from internet.
Click on below for your driver
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/HP/Hp-Photosmart-7350-42.shtml
Thanks
Robert
2answers
6helpful
2answers
Printer cartridge cradle is stuck-hp photosmart 7350
Printer
Hi, Do you have the installation CD for the printer?
k24674
Grand Canyon Tech
Grand Canyon Tech
