Tv sony trinitron 29"pakai ic mcz3001d,keadaan dingin tv di ONkan mau nyala normal.tetapi kalau sudah panas tv di ONkan lalu STAND BY dan lampu led merah kedip 11 kali.
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at [email protected] if you run into difficulties.
-Dave
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: 32 in. Sony Trinitron stand by light keeps flashing
has a sony 41" REAR PROJECTION TV THE STAND BY LAMP IS BLINLING HAS RESET IT , NOTHING. HAS NO PICTURE NO SOUND
SOURCE: sony trinitron wont turn on red light blinks standby
your tv has a power supply not working. plse take it to a shop and have it repaired.
ask the tenchnian to check the ht high tension voltage of 95-105 volts, if this is not been produced from the supply then that confirm it being fault.
he should check the semiconductor of the supply.
your supply will stay longer if you power it using a 115 volts on the in put of the supply not 220 volts. because 115 is the minimum and 220 volts is the maxmum.
okay
