Yes, you just need to connect the Airport to the modem. That way, the Airport will fetch the internet connection and distribute it to all your WiFi enabled device. You don't need any other hardware. You just need to configure the airport using your Mac computer.
Here's a quick setup guide from Apple.com:
Setup Airport Extreme
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
it look like harddisk problem is keep going. plug out the disk and try. if it continues and says there is not problem you can say mmotherboard is working well and you have really disk problem
Hi, I'm sorry to hear you are having trouble....
THis is a tricky one. My first step would be to connect another screen to your G5 and connect your V223w to another Mac... Are you able to do this, do you have access to another system, could even be a PC ( in the worst case )
Ideally, having 2 screens connected to your G5 would be the best situation.
THis way, with one working screen, you can attempt to modify the resolution and refresh rates on the V223w from the good screen, be sure to activate screen mirroring, otherwise you will not have access to the other window of monitors system preferences.
If you can get two monitors connected and mirroring is not an option, then either your monitor is KAPUT or the video card secondary port is KAPUT, try switching the port of the card your displays are connected to. I think they are both DVI ports. If the opposite screen is now working, then you know it's the port on the video card.
Hope this will get you through it.
Hi, sorry to hear you are having problems,
Are you saying that your Mac was working fine with the dead battery but then when you put in the new battery, the Mac died?
Well, if that is the case it might be possible that the battery ran down to ZERO and the mac's internal battery also is dead so, it does not even know what hard drive to boot into...
So, with the Mac Shut Down, hit the power on button and then VERY QUICKLY, press the ( alt ) key and hold it until you see a blue screen with a Big right pointing blue arrow and a circular arrow.
You can let go of the key, and the mac is now looking for suitable startup volumes to boot from...
You should see your harddive appear after a minute or so... If it does not appear, then either your system is damaged or your disk is KAPUT...
How old is your Mac? It is very very common for PowerBook drives to die after 4 years without advanced warning... :(
Good luck
What system are you running on the cube?
