Microsoft EXCEL 2004 for Mac Logo
Posted on Feb 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When trying to save a new file, no dialogue box opens and the drop down menus then grey out most items including both 'save' commands
My operating system is Mac OS X 10.6.8
David Shaub
Level 3:
President:
  • Microsoft Master 2,994 Answers
  • Posted on Feb 06, 2012
David Shaub
Microsoft Master
Level 3:
President:
Answers
2994
Questions
Helped
1153504
Points
8370
You need to uninstall the program and reinstall it.
I've lost restore down in Word. How can I get it back?
if you are referring to microsoft word
Microsoft Word is one of the most widely used text editors in the business world today.
Using Word, you occasionally experience glitches like missing Menu items.
You open Word and while preparing your document realize the Menu item you want to use has magically disappeared.
You can restore it easily.
There are ways to restore lost Menu items in Microsoft Word.
Check your Menu to confirm the button you are looking for is really missing.
Microsoft Word is intuitive and continually adjusts to show the options you choose most often.
Click the double arrow near the bottom of the Menu items to reveal the hidden options.
Click the Menu item you are looking for.
Use that Menu item often and Word will place it in your Menu for easy access.
Replace the missing Menu item in Microsoft Word. Click Tools - Customize.
Select the Commands tab.
Click Rearrange Commands.
Add the Menu item you lost in Microsoft Word.
Select the Menu bar at the top.
Use the drop down menu to select File. Open Controls.
Highlight the Menu item under the File menu and click the Add button.
Select File under Categories. Open Commands and select desired button.
Click Ok.
Word will reveal a preview of the File menu including your changes.
Select the desired Menu item.
Click Add.
To adjust the position of the Menu item you added.
Click Move Up or Move Down.
Continue to adjust them until you achieve your desired results.
Click Close to close the window.
Click File, Exit to close Microsoft Word.
hope this helps
My files are created in adobe pagemaker now I want them to convert in jpg or pdf format how?
1. Save the Pagemaker document. If you don't do this before proceeding, a pop-up box will remind you.
2. Go to File>Export>Adobe PDF. A dialogue box of PDF options will come up.
3. Determine what you want to use the PDF for. If you are exporting for a specific print job, the printer will give you Distiller settings. Otherwise, in Job Name, just choose the settings that most closely meet your requirements: High Quality Print for a printout, Smallest File Size for a document that will be viewed online.
4. Click "Export." An "Export PDF As" dialogue box will pop up. Choose the folder in which you wish to save the PDF, and name the file. Check the "View PDF" box, so the PDF will open after it has been created.
5. Watch the dialogue box. It should show that Distiller is creating the file. When finished, the PDF document will open.
Good Luck!
John Vickers
I am using Serif Draw Plus x4. Having completed the line drawing, I now want to copy it and paste it to a text box in a Word doc. What's the quickest way to do this, please? Richard Royds
Well follow my lead :
1. Click on insert tab .
2. Select the object option.
3. If you have to display the content select object menu item.
4. A drop down list will open select the serif plus program if visible if not then you can only link the file.
5. now a browse file dialogue box will open select your file that is to be shown.
6. that's it enjoy.
easier method.
1. install Ashampoo magical snap( takes screen shots from your desktop)
2. take the screenshot of your file and save it as a picture.
3. now i guess you know how to display a picture in a word document
have fun :)
vote if solved
I open WORD. I click " open file". I get my list of files, BUT, the red " close button and the "yellow" minimize buttons no longer work ( and most all other items in drop down...
Sorry, there was something wrong with the chat session, please try to reconnect the chat, with the link on the right side of the window.
6answers
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
2answers
My self rakesh,using 2007 microsoft word,how to convert the 2007 word format to 2003 format
Convert a document to Office Word 2007 The Word Convert command clears the compatibility options so that the document layout appears as it would if it had been created in Word 2007.
  1. Click the Microsoft Office Button default.aspx?assetid=za100771021033, and then click Convert.
  2. In the Microsoft Office Word dialog box, click OK.
  3. Do one of the following:
    • To replace the original file with a file in the Office Word 2007 file format, click the Microsoft Office Buttondefault.aspx?assetid=za100771021033, and then click Save.
    • To save the original document in its original file format and create another document in the Office Word 2007 file format, click the Microsoft Office Button, click Save As, and then type a new name for the file.
    Note If the original .doc file is saved in a location other than your local drive, Word keeps the original .doc file and creates a new .docx file when you click Convert.
Can't Open a New File
the registry value for that particular software must have been corrupted.... better uninstall and then search and remove the adobe photoshop registries and then reinstall....
3answers
Outlook express file recovery tool
Have a look at this follow the instructions it should make it all better.
MailNavigator can cope with the task of restoring out-of-order dbx files when Outlook Express itself cannot read them and when a range of other programs are not capable of restoring the information contained in these files. These situations can happen because of viruses, computer breakdown, power interruptions and many other reasons, leading to errors in the file system.
If your computer crashed, first of all you should make sure you have backup copies of your dbx files as well as of all other important data. It's good if you make backup copies of your data on a regular basis. But, unfortunately, in our experience situations are often encountered where there is already nothing to restore.
The process of data recovery from dbx files includes two stages:
If your Outlook Express program is properly installed and tuned, MailNavigator will automatically find the dbx files from the information in the systems register. In this case you can load the dbx files from the Information Retrieval page by double clicking on each of them. Or search for messages in these files using the search system.
If MailNavigator cannot automatically determine the location of the dbx files (for example if these files are on a CD), first you have to find them using search tools, and then load them into MailNavigator using the menu command:
File | Load External Mailbox...
eudora1.gif Once you've read the messages, select the ones that should be exported back into Outlook Express. You can use various filters to select the messages. If you want to export all the messages browsable in the Navigator at once, use the menu command:
Message | Select All
Having selected the messages, export them using the menu command:
Message | Save as...
eudora2.gif In the opened dialogue box, indicate the file and export path, and choose the file type: Eudora mailbox.
When the command is executed, there will be files in the export directory with extensions .toc and .mbx, and also a file descmap.pce. If there are attached files in the exported messages they will be saved in the subdirectory Attach.
Once the mailbox in Eudora format is created, open the program Outlook Express and use the menu command:
File | Import | Messages...
In the opened dialogue box, as the program from which the message is imported, select: Eudora Pro or Light:
In the next dialogue box indicate the directory in which you put the messages from MailNavigator at the export stage:
Further, if Outlook Express finds mailboxes in this directory, it will suggest you select one of them for import:
All that remains to do is to press the Finish button, and a folder containing the imported messages is created in Outlook Express. hope this helps
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
