Whenever the tv is turned on it goes directly to DVD/CARD and then the screen disappears. My tv plays on ANALOG, but I can't see the screen to programmed system.
That sounds like the inverter board. I would go online and search for the inverter board for that model TV. Replacing it is a very simple task once you take the back of the TV off.
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
I have a large black square obscuring the picture. You can see the picture in 1 inch border around the black square. If I reset the input switch, the black square disappears for about one second (the picture is momentarily perfect) and the black square appears again. It is not the cable box because I wired the cable directly into the tv. The same thing happens when I try to play a DVD. Any insights????
This sound like a problem with the Closed Caption, on many sets if the C.C. is set to text a black box apears, and since it only happens on DVD you might look at the DVD menu and see if it has this Text featcher in the Closed Caption menu and turn it off
Tank,
If the unit operates correctly on DVD then we can assume that the signal chain and display is operational. Can you substitute the Directv receiver to rule the box out as part of the problem? I know they came out and checked but how exhausting was the testing? Have you checked signal strength on the directv on screen setup? Low or marginal signal strength could cause intermittent blanking. When the screen goes dark does the audio continue?
please let us know..
