Can someone help me to solve my problems? Whenever I play any download games with my PSP 2000, it will popup "Do you want to quit the game". I have check that I didn't press the HOME button. But when I open the UMD door, the message "Do you want to quit the game" didn't popup at all. I can play all my games without any problems. But, is there other solution for my problems rather than leaving my umd door to always open?
SOURCE: my UMD icon dont appear when i put a game on it
I think the lens might have died permanantely, or maybe just it's temporary. I've also had the same problem, and one time I turned it on, it started working again. Wait about a day and see if it still happens.
SOURCE: Sony PSP wont play umd
Go and return this to Sony if it is under warranty or go to a nearby repair shop to fix it. I believe the diode has been damaged from the qtip being used. Those lasers are delicate things.
SOURCE: psp and umd
Open the UMD door. You will see a large peg sticking up and behind it a small one. Press down on the small one, it is either Black or Gray. This is the senor switch that senses a UMD Disc is inserted. When you press this little peg down, look at the Laser to see if it lights up. If it does not light up. You need a New UMD drive. If it does light up. Press the peg down again, but this time look at the Spindle to see if it spins any at all. This is hard to see. If it does not spin in the slightest. You need a new UMD drive. If you do not have problem with lighting or spining, then get you a Q-tip and some Glass Cleaner./ Clean the lens on the laser.
there are series of problem in psp which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the psp repair guide that will help you a lot Click Here
