Kenwood KAC-9103D Car Audio Amplifier Logo
Question about Kenwood KAC-9103D Car Audio Amplifier
Can i bridged my kac-9103d amp - Kenwood KAC-9103D Car Audio Amplifier
5 Related Answers
Anonymous
  • 109 Answers
SOURCE: No sound from KAC-9103D
What kind of amp is it?
Posted on Jun 19, 2008
Anonymous
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
Anonymous
  • 96 Answers
SOURCE: want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Posted on Jun 11, 2009
Anonymous
  • 655 Answers
SOURCE: why does the kenwood kac-9103d has two sets of
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Posted on Sep 23, 2009
Anonymous
SOURCE: KAC-9103D hooked up to two 12
I have a Kenwood KAC-9103D hooked up to two 12" KFC 3011. My amp stopped working the other day after it worked fine for about a year the blue light for the fan lights up, the fan runs and the amp runs but the red light flashes on and off and there is no output to the subs. I hooked the amp up to a friends system and it does the same thing. It also makes a tick when the red light flashes. But i have confirmed that its not the wiring. Whats up?
Posted on Mar 11, 2010
My kenwood kac 9103d just crapped out on me and i am looking to buy a new amp but when i bought my sub the guy specifically wanted to know what type of amp i had to match it to the sub. so now do i have to...
More specifically, the amp must support the resistance of the sub, or subs. If your amp is 2-ohm stable, it can run a sub, or subs wired for a 2-ohm load. Also, whatever the recommended maximum wattage is for the subwoofer, try not to exceed this much, if at all, with the amplifiers wattage.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
What size amp is the kenwood KAC-9103d amp
im not sure what you mean by what size amp....whether you mean physical size or wattage (power) so I have provided a website link for all the specifications that you require..........
http://my.kenwood.com/Car_Entertainment/Power_Amplifiers/KAC-9103D
PLease vote if you liked this response....
2answers
2answers
I want to know how to wire up 3 12' subs to the kac-9103d amp my 12's are 8 ohms
to get the most power to your subs from that particular amp and those 8 ohm coils just wire the coils in parallel and that will give you a 2.66 ohm load. You will be close to the maximum rated rms output power for the amp that way
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
Hope this helps.
3helpful
Hello laurogleal,
Hope this helps.
1helpful
3answers
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Open Questions:
See all Kenwood KAC-9103D Car Audio Amplifier Questions
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
