Question about Stanley Garden
Owners manual for a stanley 20-800 miter box saw
5 Related Answers
knite1
  • 16 Answers
SOURCE: I purchased a Craftmans 10" Compund Miter Saw with
http://www.sears.com/shc/s/p_10153_12605_00921241000P?prdNo=4&blockNo=4&blockType=G4
Here is there sears website that has the latest Craftmans 10" compound miter saw with stand. Have a look at the picture on the website and drag your cursor over the picture to zoom in on the stand... if you cant find an instruction manual for its assembly the picture is very clear and ever bolt is visible.... perhaps you can deduce from the picture how it goes together.
Posted on Jun 21, 2010
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: Cant find owners manual for Delta compound miter saw model Ms250
Go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Posted on Mar 25, 2009
Anonymous
  • 87 Answers
SOURCE: Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 09, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: I am looking for an owners manual for a Delta compound miter saw
Got it. Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number, use the type 2 on the next page and under instructions use the one beginning with "en" it is 21 pages long but it is there. If I have helped you with your question would you please rate my response accordingly and Thank you.
Posted on Sep 09, 2009
I have a stanley mitre box it has a crack in it how do i fix or find someone who can fix it.
Most manual miter boxes are made of aluminum. A good welding shop should be able to repair your box, or you can get "aluminum brazing rods" at a home center; you'll use a propane/butane torch to heat the rod and flow it into the crack, similar to soldering.
Nov 29, 2017 | Saws
Need owners manual
Go to 2heplu.com you can download operator manuals and parts lists for Dewalt, Black & decker and Stanley power tools.
Mar 12, 2014 | Dewalt 12" Beveling Sliding Compound Miter...
The motor brake on my pro tech miter saw doesn't function. Is there a doable fix ? Also need an owner's manual
The brake on saws like yours are controlled by the switch. They do go bad and are easily replaced if the parts are still available. Your heading says you have a Makita tool but you didn't give the model number. If you go to the Makita home site at:
www.makitatools.com/en-us/Modules/Home/Default.aspx
you can put your model number in the search box and get a parts breakdown and owner's manual if they are still available. Parts are available online at sites like www.ereplacementparts.com where you can also get a parts breakdown but not manuals.
Jun 06, 2012 | Makita 10" Dual Bevel Sliding Compound...
My saw is really stiff when you try to change the angle .I oiled it but this didn't help. I would like to know how to take it apart but I am un sure how to do it and what is in the boxed off area...
Exploded diagram with parts list for LS1016 10" Dual Slide Compound miter saw is here.
Owner's manual is here. If these aren't quite what you need, you can view other models of Makita miter saws, here.
One thing to bear in mind. There's a miter angle lock and a slide lock on the bottom front of the saw. If you don't have the miter angle lock loose enough, it will be difficult to turn the saw.
If this answer was useful, please vote for it. Thanks!
Apr 14, 2010 | Makita 10" Dual Bevel Sliding Compound...
Cove molding angles
Watch this video...
http://tinyurl.com/pup4zhf
Sep 27, 2009 | Stanley Tools/Goldblatt Tool No.20 - 600...
What do i do to cut inside/outside corners for crown molding
It is very hard to make proper cuts with one of these.
You may want to buy a power miter saw.
You would be better off marking your 45 degree angle and cutting it freehand.
If you angle your saw a little the face will look like it matches up better.
If you need more help post a comment.
Tim
May 03, 2009 | Stanley Tools/Goldblatt Tool No.20 - 600...
Garden Logo
650 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
