LG LMVM1945 Microwave Oven Logo
Question about LG LMVM1945 Microwave Oven
LG Microwave oven - clock works nothing else does. Will not enter cook time. No fan or lights either
Just stopped working. No fan, lights. Won't allow you to enter cook time. Only thing working is the clock and 30 second quick cook button but even that is iffy.
Posted by Bonnie Brehun on
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: LG 1925 Microwave suddenly stopped cooking, other functions work fine!
What you said about the the clock leads me to suggest that you first unplug it for a few minutes then plug it back in. It may just need a good reset. If you don't have your owner's manual you can download one here: http://www.lge.com/support/manual.jsp The mention of odor concerns me. It may just be a bit of food or grease on the waveguide cover, which is a small sheet or panel on the wall or ceiling of the cooking cavity, but it may indicate the failure of a part in the high voltage section. You may have an intermittent door switch. You can see some of my other responses for info on how to get our important text file that helps you diagnose and repair door switches and gives important safety tips.
Posted on Dec 11, 2006
Anonymous
  • 132 Answers
SOURCE: Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
Anonymous
  • 4 Answers
SOURCE: microwave oven not working right
if the time of day is not programmed it wont work.... did u do that?
Posted on Sep 21, 2009
Anonymous
  • 5911 Answers
SOURCE: I have this unit and it just stopped working.
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven, UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at searspartsdirect.com based on the model number you listed this question under:
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f50026410-00007.png
The line fuse is listed as item 8 (part number 3B74133K). There is a another fuse listed as item 2 (part number 3B72974C), but this is a thermal fuse for the fan motor.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended. If you wish to order on line, use the part numbers to search by comparison as the model number you listed this question under is not available at all the websites I have provided. The parts, however, ARE listed.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. To answer your initial question, "yes", these ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find any of the internal fuses blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Posted on Apr 28, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Cooked food is not getting heated in my microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hhg
Posted on Sep 30, 2010
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
The problem is that when I press the 'Start' button, nothing happens. The clock is working, the fan is working, but I cannot cook anything even after I have entered the time and the power level
If when you press the start button the turntable starts but no heat then magnetron is faulty otherwise if nothing happens then the touchpad itself is faulty.
1helpful
Does not cook - time counts down extremely fast
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
No heat
heating element stopped working
easiest thing is to get a new microwave
1helpful
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
Top LG Microwave Ovens Experts
Muzahura Frank
Geoffrey White
Geoffrey White
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
